0 members (), 83 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Van
Van
Wife wanted to drive her Apache to work after we were headed to breakfast at a local joint. Was following her down a secondary road when all of a sudden it looked like she threw a cigarette out the bottom of the truck! (she don't smoke). Turned out the upper left bracket the shock bolts to broke clean off. I ran home in car I was following her with and retrieved a tool box and removed the shock from the truck and she drove it back home no problems. Upon further investigating I see the other one is cracked in same fashion. After looking online a bit I see different looking brackets for replacement but they dont look anything like mine. Mine are flat metal with the pin for the shock mounted 90deg. at the top. Three rivets hold the flat portion to the frame. The ones online look like they have two rivet holes that mount to the top of the frame. Are these a better style stronger way to go? Should I just weld mine back in place and weld over the other cracked one? I might be able to add a reinforcement plate to the inside across the stressed area.
Any help or light shedding on this subject is greatly appriciated!
Even if you have had this happen before post here please
RK
ie.my apologies. I thought driveline meant engines/transmissions/rearends?
1959 Apache swb stepside
Atlanta Ga.
Bolting or welding anything to a frame flange can create stress risers that can lead to frame cracks. I'd suggest making a 1/4" thick reinforcing plate that fits inside the cracked/broken pieces, drilling and bolting it in place, and then welding over the cracks. That way, no frame alterations are made, and you've got a stronger than original part on both sides.
I wouldn't be afraid of welding the bracket back together while it's riveted to the frame. There shouldn't be enough heat transfer to the frame itself to affect the strength. If you did that, you might want to reinforce the bracket a bit around the welded area.
But like Jerry said, don't weld on the frame.
I hope you cn get that fixed easy! In wondering how the brackets could break, I’m thinking a past owner who drove a rough road for a very long time, had put on extra stiff shocks and kept them maintained that way, and that exceded the engineered strength of the bracket. With constant flexing for a long time ...... Just a considered guess. I agree with Kevin, the heat of welding in place on the bracket wouldn’t heat up the frame enough to make stress spots. Might be easier to do on the bench, though. Re- riveting the bracket to the frame would be a fun job! Take an old sledge hammer head(annealed)drill or machine a recess on the face that fits the rivet head nicely, and use this for a buck. Have the truck’s owner hold this while you peen the other end nice and tight. Get the rivet fairly red hot first. At least the little end. Or, you could switch ends with the owner, so she won’t feel like you are undervaluing her skills. Got to keep peace in the marriage! Might pay off. wink
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Other than an easy but inconvenient weld fix- how about your wife that drives an Apache tri-five truck. Awesome!
1946 GMC Project
"Back-in-the-day Restore"
You might check if the correct shocks were used. If they didn't have the proper travel, they would have put stress on the bracket. Otherwise, they shouldn't have reached full travel.
Dennis
40 Chevy 1/2 ton
RK, Had the exact same problem on my '58 Apache and was broken when I got the truck. And rather than a crack on the mount that was intact it had already been welded some time before I acquired when I got the beast (no idea how long it had been that way but it evidently held for some time). Guessing they both were not welded because the shock and portion of one mount was lost when the damage was done.
Experienced the same thing you did when trying to find something new - nothing that is correct. I watched eBay for several months and got lucky finding two NOS mounts for a very good price (too long ago to remember but under $20 for both). Ground the rivets off and plan on attaching with bolts when I finally get around to putting shocks on. I'd guess someone really hit a dip/curb/pothole really hard to compress the shocks completely and transfer additional forces on the shock mounts.
If too-long shocks are installed, hitting any hard bump could compress them fully and put excessive strain on the mounting brackets. You could also use the existing brackets as a pattern and duplicate the mounts in flat steel plate. The shoulder bolts the shocks mount to are available, and as long as they fit the rubber bushings in the ends of the shocks, they don't really care what vehicle they're on.
' Offline
RK ,
Why go thru all of the trouble to repair or fabricate new brackets
when you can buy GM NOS Lower Frame Shock Brackets - .GM # 3902543
These lower frame shock mounts are now a very rare part to find GM NOS .
GM # 3902543 was discontinued by GM in 1990.
The original GM part # was GM # 3882338 and was superseded in 1967 .
There is an auction on ebay that ends very early the morning of March 6th. @ 7:47 AM west coast time .
I would not miss this auction .
As a bonus in this odd lot auction it also has ( 2 ) upper shock brackets - GM # 3700440 .
These upper brackets would sell fast .
Sell the rest right back on ebay or right here on stovebolt.
PIC
https://i.postimg.cc/R0PSj9DZ/3902543.jpg
Go to ebay & in the search box TYPE........3700440.........or..........3902543
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Van
Van
Thanks fellas!
I will check out that auction for sure. Thanks for the part numbers too! All I could find initially is those top frame mounts. Not sure if I could make those work or not.
The shocks are gas, and the PO. replaced them before I purchased the truck. So, I didn't think to look there. The P.O. owns operates a 18wheeler truck repair business. I figured He looked at things. Thats what I get for assuming eh?
Yes my wife drives the Apache better than I do!
RK, aka Van
Atlanta Ga.
Broken shock brackets are common on AD trucks and they make replacement ones, I thought they did for task force too. Mine had a coil over shock and that was the reason it broke, I'm sure. Stay away from these types of shocks, they have no reason to be there.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Van
Van
Wow I want those from Ebay!
How much do you think that entire collection is worth?
He didn't leave a buy it now price.
I'd want to bid a resonable amount and I'm not an avid ebayer
RK
Atlanta Ga.
' Offline
I've purchased many bulk mixed part lots on ebay .
Then I sold the unneeded parts on ebay .
Quite a few times I was able to make money after keeping
the parts or part I needed.
A lot of these ebay sellers are lazy & don't want to take the time to
list individual parts .They usually got the whole lot for nearly nothing .
The seller doesn't have a buy it now price . The high bidder takes the entire lot.
The front upper brackets , you could probably get $50.00 to $75.00 for the pair .
Sell a pair of lower frame brackets , I'd want at least $50.00 for a pair .
You need a pair of lower brackets & they are there for you to bid.
If I needed those lower brackets...........I'd wait till the auction got down to
30 seconds or less & slam home my winning bid .
I'd bid at least $125.99 , then you can recoup your money by selling the parts one at a time back on ebay.
By bidding $125.99 doesn't mean you will pay $125.99........it means you'll bid a dollar above the current high bid .
I think a bid of $125.99 would win you the auction with plenty of change .
Don't bid now.........wait till the very end & BAMM.........BID !
Good luck with the auction .
I've searched the internet & all of my sources for the lower brackets that you need .
They are not available !
The only ones available are the ones on ebay.
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Van
Van
OK! I placed a bid! Hopefully I'll get it. If I do I'll have a few extra parts to sell :-) I'll be watching it tomorrow.
RK
Atlanta Ga.
' Offline
RK ,
I see you put a bid in on the parts lot.
Every body to their own way of bidding.
Some of these ebay sellers use bid shills to pump up the price.
The bidder that is now in second place had a backdoor hidden bid of $36.00
There are lots of watchers on this parts lot .
I'd expect some more bids to follow.
Hope you get it .
I always wait till the last 10 / 15 seconds to bid because of the bidding shills .
Good Luck,
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Van
Van
Yeah I saw that last night. Did not know it was called shills? Its worth the 37 its at right now. in fact its worth about double that to me but not more than that. If it goes higher I will just resort to welding my old ones.
RK
Atlanta Ga.
Van
Van
I GOT IT !!!!!!!!!!!!!!!!!!!!!!!!!
Cost me $65 WOOT!
Maybe I should buy a lottery ticket today?
Thanks fellas!!
rk
Atlanta Ga.
Van
Van
Ok after goingback thru this thread I've got a few newbie questions please.
SSTOCK, What excactly is an AD truck? also whats task force mean that you mentioned above?
I've seen AD truck referenced in here a lot but don't have a clue?
Tom Moore,Whats a tri five apache? Mine is a 3100? It is a 3 on the tree.
Atlanta Ga.
Van
Van
Ahhhhh AD= Advance design (of the era). That answers a lot including task force question. Kinda backwards inasmuchas meant to be a work truck but appeal to city slickers as well.
Thank you Tclederman !
Atlanta Ga.
This thread is moving sideways - sorry.
GM/Chevrolet document introducing Advance-Design trucks.
Note the use of a hyphen between Advance-Design.
The vast majority of later GM/Chevrolet documents/advertising used the hyphen.
' Offline
PIC
https://i.postimg.cc/cJDfW7WN/GM-3902543-Upper-Front-Shock-Mount-GM-NOS.jpg
Some people only know how to ridicule & don't know how to thank someone for their
help in finding a part . I'll know next time who NOT to help find a part .
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Van
Van
I wonder why this says Lower shock mount when on my 59 its the upper?
Atlanta Ga.
Just to muddy the waters a little (I'm good at that!)- - - - -"AD" is also used on occasion to describe stovebolt trucks from the late 1930's and early 40's- - - - - -the "Art Deco" trucks. That's why the A-D description with the hyphen might be worth using.
Art Deco was not a Chevrolet designation, but it is a nice name.
Advance-Design was a Chevrolet designation.
Van
Van
Well here's an update.
y'all know I won the ebay bid for those parts right?
I've been watching the tracking number on USPS (Untied States Postal Service). On thier website. I had not received the parts as of March 16 (Sat). Checked USPS again Sunday morning and they posted resident refused delivery!!!!!!!!! I was home all friggin day!!!!
Thier site said returned to sender!
I contacted the seller on ebay. He said He'd let me know when they showed up and will resend them via UPS or Fedex.
So I wait some more.
I think they delivered to wrong address.
(sigh)
Atlanta Ga.
As an Ebay Seller and Buyer I offer this advise to you:
Don't be Mr Nice Guy, immediately contact Ebay Customer Service and file a not recieved item report to cover or recover your loss.
There is not a tool made that if you don't try hard enough you can't break!
1952 3100 261 T5 3.08 Gov Locker
I agree with Rustnut.
Can you check your order receipt to be sure you gave the correct address?
Can you check you email-notification to see if the delivery address was correct?
Van
Van
I called ebay for sure
The address in ebay associated with my account is correct.
The USPS website doesn't show where they tried to deliver it to. They don't want to be embarrased I reckon
Atlanta Ga.
Van
Van
Well guess what?
The post office delivered an empty torn open box back to the sender !!!!!
He sent me pictures of it
Its no wonder they wouldn't deliver it to me.
The seller wants me to ask ebay for a refund
I think the seller should have insured the package and should send me a refund and get his money back from the post office.
He informed me that this is the 3rd package that the USPS has destroyed that He sent in the last two weeks.
Atlanta Ga.
Man that sucks. Those parts are likely gone forever. frown
The seller has some responsibility in this to package stuff sufficiently well to survive a trip thru the mail. I've sent quite a few odd shaped and relatively heavy items similar to those shock mounts successfully. The boxes need to be reinforced. You can't just throw them in an unreinforced cardboard box. Heck, I even sent myself 50lb of scrap lead from CA to AK in a flat rate box, but I doubled the box up and filled the empty space with more cardboard, and use fiberglass reinforced packing tape. It survived intact with just a few surface blemishes. Probably got a few curses from the postal carrier though. wink
The boxes not only need to be reinforced, but, the contents need to be surrounded with enough bubble-wrap/etc such that the contents do not burst-through the sides/ends of the box when the shippers throw the box around.
I received a Silver Book in a Priority Mail box - the book had flimsy plastic around it. The end of the box was spread open, and the binder on the book was broken - because it moved rather easily inside the box.
Other Silver Book shippers much more carefully packed in the same box - no damage on the book inside, but a little crumpling of the box on the outside.
Van
Van
Well, I called ebay.
They said they were going to notify the seller and he has until the 25th (march 2019) to send me a refund.
I want the money back sure but I wanted the parts worse.
54 3100 posted a picture and a part number but I cannot find them anywhere yet.
Guess I'm back to welding them myself.
Atlanta Ga.
Van
Van
I'm wondering if I can get them manufactured what kind of market would there be?
Atlanta Ga.
Try a parts-wanted ad, here in the Swap Meet. You got nothing to lose.
Maybe someone who has swapped out their front suspension will have those part in a pile of "scrap"?
Be sure the post make, model, year truck.
Van
Van
trying to post pictures
Finally got it welded and painted!!
with jackstands under the axle beam the distance between the shock mounts should be where it would sit with tires on the ground correct?
I compressed the shocks I took off and I'd say there is about an inch of compression left before it bottoms out.
Can anyone tell me the correct length of shocks I need or a good part number? 1959 Chevy Apache 31
Thanks!
Atlanta Ga.
Sir Searchalot
Sir Searchalot
You don't really need to know the correct length of shock. You just need to buy the correct shock. Go to Rockauto. Look up 1958 NOT 1959. I see plenty of part numbers to order from them or use elsewhere. Also, several of our normal vendors carry the shock.
Info seems to indicate extended length= 20 1/4, Compressed length= 12 3/8
Not a good idea for us to post part numbers. They change, become obsolete or we could error. This post will be viewed many years from now. Up to you to search and find what number is in stock, as per my above. Rockauto, Classic Truck Parts of America, Jim Carter, Napa, Summit................Autozone, O'Reillys, whatever. Learn to search for parts on the internet. That's what we all had to learn. Make an effort. If you can't find, then post again. Old part numbers from old parts books are NO GOOD.
I surely did not know all that stuff I just posted . Had to look it all up for you. Glad to help but; "look it up for him for one part or teach him to search and find parts for a lifetime."
Van
Van
thank you for the length measurement!
That is most helpful.
Most of the shocks I looked at online offered nothing other than year fitment or ads about how good they are or warranties offered.
Also did not know to look at 1958 exclusively. Most say 58-59.
Atlanta Ga.
