8 members (GA Boy, 55shaker, Jay R, 32vsnake, Goach2, Ridgeback, 3B, Charles in CA),
95
Mod | | | Forums66 Topics128,198 Posts1,057,270 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | Yes, I’ve tried to read the forums first, with no luck 59 gauge cluster needs removal. I’ve unscrewed everything but oil sensor When I pull on the cluster it only moves about 1/2 inch then clearly stops with a thud. Reaching in behind, it feels like the bezel has a lip all the way around and feeling with one hand, while pulling with the other, I can feel the lip bottom out on the opening. Am I missing something? It’s not a wire or Speedo causing resistance, this is clearly a metal on metal thud, like the back edge of the bezel is too big for the opening.
I can’t get it out. Any help? Thanks
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is catching on the inner edge of the dash board. I don't remember exactly but it seem like I pried down on it & bent the edge of the dash down a little.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Yep it doesn't come out easily, you have to turn your head at an angle with mouth open and tonque hanging out the side of your mouth. Then make some funny noises and say a few non technical words and it will come out.
Tommy 59 apache 1/2t 261 short stepside | | |
