4 members (Biermann, ndkid275, Wayne67vert, Peggy M), 168 guests, and 4 robots.
Topics128,164
Posts1,056,965
Members48,458
#1301325 03/02/2019 5:58 AM
Here is how one sets if no rear spring mods are made. Some like a severe "rake" but I,m not one of them.
[img]https://i.postimg.cc/PLZF45F8/IMG-4757.jpg[/img]
Evan
Thanks, that answers a lot of questions.
1951 Chevy Panel Truck
Hmmmm- - - -looks sort of like a hound dog after a close encounter with a skunk, doesn't it?
LOL!
A Mustang II ride height can be set anywhere. Not necessarily in a raked or low position.
Exactly, depending on how low or high one mounts the MII crossmember in the frame.
Fox Offline
Does that use drop spindles or is it a “stock” height spindle?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
The picture is an out of the box MII cross member welded to a factory height frame---no dropped spindles. Was intended as a primer and not a history of clock making. Of course the cross member can be dropped (picture) but how many also take into consideration that the change in roll center most likely will require change in spring, shock, and sway bar rates. Great variable here as a sectioned roadster will require little while a top heavy panel may take quite a change. Was not directed at pro builders but what a regular guy with a one car garage and a buzz box welder should expect as an end result.
Lowering a cross member: (frame upside down in pics)
[img]https://i.postimg.cc/yDRyTzvD/raise-MII-XM-001.jpg[/img]
[img]https://i.postimg.cc/670RH6Rp/raise-MII-XM-002.jpg[/img]
[img]https://i.postimg.cc/rKxDnF22/raise-MII-XM-003.jpg[/img]
Evan
My 39 looked like that as well with a Hiedts kit. When I bought my kit, I asked for "stock height" spindles, but they sent me 2 inch drop spindles. I removed a few rear leaf's and got it to a manageable rake. After a few years, I realized that I had drop spindles. I installed a set of "stock height", and it brought the front up a bit.
Another quality post.
Real Trucks Rattle
