1 members (sron48),
124
Mod | | | Forums66 Topics128,164 Posts1,056,966 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Thanks, that answers a lot of questions.
1951 Chevy Panel Truck
| | | | | Joined: Feb 2004 Posts: 29,860 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,860 | Hmmmm- - - -looks sort of like a hound dog after a close encounter with a skunk, doesn't it? LOL! Jerry
| | | | | Joined: Oct 2005 Posts: 4,259 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,259 | A Mustang II ride height can be set anywhere. Not necessarily in a raked or low position. | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | A Mustang II ride height can be set anywhere. Not necessarily in a raked or low position. Exactly, depending on how low or high one mounts the MII crossmember in the frame. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Does that use drop spindles or is it a “stock” height spindle? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The picture is an out of the box MII cross member welded to a factory height frame---no dropped spindles. Was intended as a primer and not a history of clock making. Of course the cross member can be dropped (picture) but how many also take into consideration that the change in roll center most likely will require change in spring, shock, and sway bar rates. Great variable here as a sectioned roadster will require little while a top heavy panel may take quite a change. Was not directed at pro builders but what a regular guy with a one car garage and a buzz box welder should expect as an end result. Lowering a cross member: (frame upside down in pics) [img]https://i.postimg.cc/yDRyTzvD/raise-MII-XM-001.jpg[/img][img]https://i.postimg.cc/670RH6Rp/raise-MII-XM-002.jpg[/img][img]https://i.postimg.cc/rKxDnF22/raise-MII-XM-003.jpg[/img]
Evan
| | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | My 39 looked like that as well with a Hiedts kit. When I bought my kit, I asked for "stock height" spindles, but they sent me 2 inch drop spindles. I removed a few rear leaf's and got it to a manageable rake. After a few years, I realized that I had drop spindles. I installed a set of "stock height", and it brought the front up a bit.
