7 members (TUTS 59, homer52, Otto Skorzeny, Youngin' Tut 59, dt235sd, 2 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
#1301179 03/01/2019 2:33 PM
Can someone show me where the small ground wire on the negative battery cable is attached? I don't see a dedicated hole for a ground terminal screw on the radiator support or inner fender. I'd like to use the factory ground point.
Thanks!
H Online: Content
Which truck? If you've got a "small" ground cable, your life is going to get interesting, and not in a good way!
Many of the aftermarket cables both positive and negative have the secondary wire (usually about 10 gauge) coming from the battery connection fitting. Just because it’s there doesn’t mean your particular vehicle had one from the factory. Always tell us what vehicle your working on in EVERY thread you start. It will help us help you.🛠
H Online: Content
That extra ground can be attached to any convenient body panel screw, or just scrape a spot down to bare metal and drill a hole for a big sheet metal screw. Electrons aren't picky about where they go on the way back to the battery, and since electric current approaches the speed of light, a few inches plus or minus on a car body makes no difference.
1969 Chevrolet truck?
Here are some sources.
Sir Searchalot
Sir Searchalot
If you really mean the "small" ground wire that comes with the big cable. I've never attached it to anything. I suppose there are gadgets to add under the hood that you could use it for someday. Wolf whistle horn?
My 1966 C10 Pick-up and 1966 Suburban have it attached to the radiator support.
