7 members (tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible), 198 guests, and 4 robots.
Topics128,108
Posts1,056,231
Members48,436
Hello,
What are the differences in ORIGINAL VS. "REPOP" hinges?
Mark's, numbers, ect.
The ones I just pulled shows pretty good wear, pins ect. Just wondering the differences.
As always, Thank you.
1950 Chevy 3100
In the ideal world there shouldn't be any differences. Most of these if not all, are manufactured in China and some people here say that they just don't work like they should or there are fit and latching issues.
I tend to monitor websites and vendors that sell NOS parts for items such as hinges and latches because fitting doors and getting them to seal and latch is difficult enough.
I used a repop set on a 59 GMC once and took them off and found that even the worn latches worked better than the new repop latches. I jjut spend a little time on restoration and repair of the originals.
1946 GMC Project
"Back-in-the-day Restore"
Fox Offline
Differences?
One type will work. (Or can be fixed easily)
The other will really make you crabby.
Fix the old ones or get NOS as Tom suggests. I had to weld up my striker plates, latch claws, rebuild the hinges with bushings and pins, and tweak the hinge arms.
IT WAS WORTH IT. I close my doors and THUD. They close beautifully.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
