9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman), 93 guests, and 2 robots.
Topics128,069
Posts1,055,886
Members48,428
#1300900 02/27/2019 7:27 PM
Just wondering if anyone knows if the car 5th gears from a NWC t5 are compatible with a NWC T5 from a truck.
wolffcub #1300937 02/28/2019 12:40 AM
ASU Offline
Wolffcub,
I think we need more information to be able to give a good answer. The T5's were in Camaros, mustangs, minivans, s-10's blazers, Jeeps, AMC's.....and the list goes on.
The information needed is on a small tag on a tail housing bolt(1352-XXX). Casting numbers are not definitive.
Jon
wolffcub #1300944 02/28/2019 1:23 AM
ASU, maybe you can answer my question on a t5. I have no tag and pick mine up at a salvage yard. Any way to tell year? It was supposedly in a s-10. The shifter is not in the rear of tailstock but in the middle. Also are the electronic pickups for speedometer all the same? Thanks Bill
1937 GC
wolffcub #1300985 02/28/2019 4:09 AM
S-10 nwc t5 now and want to install a chev car 5th also from a nwc. Would be awesome to figure out what the stamped numbers were For the 5th gears so I know what ones were what.
wolffcub #1301019 02/28/2019 3:36 PM
V
VEW Offline
V Offline
LUGNUTZ would be able to answer your questions.
https://lugnutz65chevystepside.weebly.com/t5-info-page.html
~ Victor
1957 3100 - moved on
wolffcub #1301042 02/28/2019 8:16 PM
I asked over a week ago but have not yet got a response.
wolffcub #1301049 02/28/2019 8:46 PM
Wolfcub, send a private message to Lugnutz. Sorry, sometimes questions just don’t get answers.
wolffcub #1301120 03/01/2019 3:41 AM
Borg Warner used a wide variety of gears and gear cuts in the T5. The countershaft dictates what the drive train gear must be if a gear must be replaced. It’s usually best to get a complete gear set along with the matching countershaft if the price is within your budget. Swapping 5th gear is usually pretty easy and there are fewer variables.
Sorry if I missed your question on my BLOG.
I know that Chevy S10 gear sets should be kept together (gears 1 thru 4). In other words, individual gears will not necessary exchange into another transmission.
A Chevy 5th gear set can be exchanged into another Chevy T5, but there are exceptions. World class 5th gear sets should exchange with NWC sets too, with some exceptions. I wanted to swap a 0.76 OD gear set with a 0.72 set but the main shaft was not machined at the proper place for the needed C-clip, so I couldn’t do it.
If you are wanting to change the OD gear ratio, please keep in mind that swapping a 5th gear set from an S10 with a V8 Camaro 5th gear set can be done, but the OD gear ratio will change. Here’s a video I made to explain why. LINK HERE
