3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
This idea won’t please everyone, but this method was perfect for my hood, hinges and hood latch. My 1963 is crusty on the outside and will likely stay crusty. I just completed an engine swap and felt that to do the job right, I needed to restore the engine bay as well. So here is a small contribution from my BLOG showing how I made sure all the parts aligned well during reassembly. LINK HERE
Nice!
I do the same thing for doors. For each hinge, I drill one hole through the door on the inside, through the hinge strap and through the sheet metal on the other side of the hinge strap.
Like Lugnutz indicates, it is important to use a sharp bit. A dull one or a poorly centered sharpened bit will walk and not make a precise hole. I splurge and buy a high quality bit just for this work.
If a purist has a problem with a few extra holes, that is his prerogative. Not a problem at all with me. He can have "fun" battling with his truck. He might need to avoid the hits from a show judge.
He would not find my holes because the door panel covers them. However I am now screwed, since tclederman is now privy to my cheating. smile
Carl
computerdeath
shake as I have always hummed, "do what you like"
52Carl,
Thanks for the affirmation. Some of the Facebook “dudes” are claiming they spray rattle can around the bolt head to mark where to line it up. I’m not proud, but I can’t imagine what that looks like after reassembly. Maybe they use tempra finger paint like in kindergarten and then wash it off. ohwell
You're a genius! My method has always involved hurriedly tearing everything apart, throwing it loose in a pile, then painstakingly adjusting it back together months later after I've forgotten how everything goes.
1951 Chevy Panel Truck
Jay, as usual, nice job.......and to add to this conversation sometimes I drill those 1/8" holes and put a "roll pin" in it and leave it even after reinstalling the hinge or other stuff.
That's another great idea, Alvin. That way you can be absolutely certain that nothing shifted while tightening up bolts.
Now I feel like I need to take all of my trucks apart and redo all of this. Well, maybe not...
Carl
Or maybe a screw or pop rivet for positive hold...
Well son of a....I wish I'd have read this two weeks ago before I started tearing the front end apart on my '49. Everything closed perfectly on it before I took it off. Great idea!
Matt M.
'49 Chevy 3100 5 Window (Project, started Feb 2019)
V
VEW Offline
V Offline
Good idea Jay...and nice job on the resto!!!
~ Victor
1957 3100 - moved on
That’s just awesome! What a great way to get everything back exactly where it belongs! Thanks for posting the pics and video too.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
I remember the probably Hotrod magazine tip suggestion for drilling a 1/8in hole in hood hinges back when I pulled my first hood in 1972, which was how you lined up a Hurst shifter too with a 3/16 inch rod.
