Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#130055 02/10/2005 10:50 PM
I am swapping rear ends this spring, also converting to 5 lug discs up front and want to do the dual mastercylinder up front.
Can I run discs up front and drums in back with the dual master kits?
Chris
Chris 1955FirstSeries
Riding in the Passing Lane
Yes! Be shure to get the coresponding master cylinder.
1972 Chevy c10 Cheyenne Super
I have a dual master cylinder with disc brakes up front (from a 1982 Monte Carlo) and drums in the rear (Chevy 12-bolt) and my truck stops real nice ... especially after cutting about 3 inches off the brake pedal post - that made a huge difference in leverage, making braking MUCH easier than before!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Sure.
I have disks on front, drums on rear, with a dual master. I used the ChevyDuty disk kit with '73 Chevelle brakes and master. Ran all new brake lines at the same time.
Works great!
Thanks guys,
I appreciate all the feedback. I am looking at the kit Chevy Duty sells for around $800 that includes the disc conversion as well as the dual master cylinder that mounts in the original position.
Alan, I like the idea of shortening the brake pedal, nice!
Thanks Everyone,
Chris
i did the replacement last summer and still having problems with brake balance. rear lock up to soon. i used the kit from brothers. i don't think it is their fault. but i still stumps me. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I used a kit from Buffalo and Frd 9"/w drums. Ron, I have a balance adjuster and residual valves to balance the lockup. Seems to work fine.
Dennis
40 Chevy 1/2 ton
I used the dual master cylinder power unit from Chevy duty that mounts in the original position.Works very good.Discs front and drums rear.
i was told that it was balanced already, not so but i will correct it this spring. it was worse until they replumbed , they had it backwwards. the old ( i never seen one them things before.) plan to order the proportioning valve in a couple of weeks. ron
2017 Buick Encore
See more pix
