2 members (Peggy M, MTD91),
141
0
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I am swapping rear ends this spring, also converting to 5 lug discs up front and want to do the dual mastercylinder up front.
Can I run discs up front and drums in back with the dual master kits?
Thanks, Chris
Chris 1955FirstSeries
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes! Be shure to get the coresponding master cylinder. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I have a dual master cylinder with disc brakes up front (from a 1982 Monte Carlo) and drums in the rear (Chevy 12-bolt) and my truck stops real nice ... especially after cutting about 3 inches off the brake pedal post - that made a huge difference in leverage, making braking MUCH easier than before!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Sure.
I have disks on front, drums on rear, with a dual master. I used the ChevyDuty disk kit with '73 Chevelle brakes and master. Ran all new brake lines at the same time.
Works great!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Thanks guys,
I appreciate all the feedback. I am looking at the kit Chevy Duty sells for around $800 that includes the disc conversion as well as the dual master cylinder that mounts in the original position.
Alan, I like the idea of shortening the brake pedal, nice!
Thanks Everyone, Chris
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i did the replacement last summer and still having problems with brake balance. rear lock up to soon. i used the kit from brothers. i don't think it is their fault. but i still stumps me. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I used a kit from Buffalo and Frd 9"/w drums. Ron, I have a balance adjuster and residual valves to balance the lockup. Seems to work fine. Dennis
40 Chevy 1/2 ton
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I used the dual master cylinder power unit from Chevy duty that mounts in the original position.Works very good.Discs front and drums rear. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i was told that it was balanced already, not so but i will correct it this spring. it was worse until they replumbed , they had it backwwards. the old ( i never seen one them things before.) plan to order the proportioning valve in a couple of weeks. ron
