5 members (37 GC, Dusty53, sron48, Vice-Grip, Otto Skorzeny), 130 guests, and 0 robots.
Topics128,114
Posts1,056,613
Members48,450
#1300187 02/22/2019 6:41 PM
I have a "1954 Chevrolet Truck Shop Manual1954 Models". It is missing Chapter 8 (Fuel and exhaust). I am looking for some information for installing the exhaust and intake manifold. any help would be appreciated. Thanks
Have you tried the Chevy Online Manual Project?
1954 Chevy Truck Shop Manual
Dave from Northern Kentucky
My 54 3100
Thanks. I looked at the manual and it did not have what i was looking for. I will print chapter 8 and put it in my manual
Appreciate your help.
What are you looking for?
Steps 15 and inwards on this page?
When i removed the exhaust manifold, the two end bolts (studs) did not have nuts on them. Are they just guides for installing the new manifold. They are threaded but do not protrude foar enough to get nuts on after the manifold is installed. i was looking for a torquing pattern for the manifold bolts. Thanks
Frank
The intake manifold end/alignment posts on both ends of the the head were used on Chevrolet Stovebolt Sixes; however, bolts were used at both ends of the same era GMC sixes.
I think that people have reported that they have removed the Chevrolet end studs and replaced them with threaded boots. I do not remember if the Chevrolet end/alignment studs were originally press-fit or threaded?
Mine are not in bad shape i just wondered if there are suppose to be nuts on them. sounds like they are just alignment.
Thanks for the help. i will try it shortly..
thanks again.
