| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | I have a "1954 Chevrolet Truck Shop Manual1954 Models". It is missing Chapter 8 (Fuel and exhaust). I am looking for some information for installing the exhaust and intake manifold. any help would be appreciated. Thanks | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Have you tried the Chevy Online Manual Project? 1954 Chevy Truck Shop Manual | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | Thanks. I looked at the manual and it did not have what i was looking for. I will print chapter 8 and put it in my manual Appreciate your help. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | When i removed the exhaust manifold, the two end bolts (studs) did not have nuts on them. Are they just guides for installing the new manifold. They are threaded but do not protrude foar enough to get nuts on after the manifold is installed. i was looking for a torquing pattern for the manifold bolts. Thanks Frank | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The intake manifold end/alignment posts on both ends of the the head were used on Chevrolet Stovebolt Sixes; however, bolts were used at both ends of the same era GMC sixes.
I think that people have reported that they have removed the Chevrolet end studs and replaced them with threaded boots. I do not remember if the Chevrolet end/alignment studs were originally press-fit or threaded? | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | Mine are not in bad shape i just wondered if there are suppose to be nuts on them. sounds like they are just alignment. Thanks | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | Thanks for the help. i will try it shortly.. thanks again. | | |
