Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (cmayna, Barney1951, Jaison, 1 invisible), 42 guests, and 5 robots.
Topics128,010
Posts1,055,305
Members48,419
#1299940 02/21/2019 1:21 AM
I understand this topic has been done to death, so I begrudgingly ask about the 3 speed overdrive setup. I would like to have the governor in use but not the kickdown switch. Could I use a toggle switch to turn it off and on and the cable to lock the overdrive in or out? I have a relay in the fuse box I'm installing and wondering if i can run it through that instead of separate one. I'm ordering my harness from Jim Carter, they say wiring instructions are included, but I'm trying to plan ahead.
1958 Chevy Grumman Olson step van
Chaz 58 #1300071 02/21/2019 8:21 PM
V
VEW Offline
V Offline
Yes, I wired mine that way.
I'll dig out my wiring diagram, if you want it.
Being able to engage the solenoid directly gives you the added benefit of "hill holding". When you're at a stop light that's on a upgrade and someone is right behind you, engage your solenoid (via switch), let your truck roll back slowly until it engages, then turn the solenoid off. Your truck will stay right where it is, without the brake. When you start moving forward, the overdrive immediately disengages.
~ Victor
1957 3100 - moved on
Chaz 58 #1300072 02/21/2019 8:32 PM
Is there some reason not to use the kickdown? Once the OD is engaged, it won't disengage above 30 MPH unless the kickdown switch is used. I'm not sure if turning off a manual switch would allow the solenoid lock pawl to retract, unless the clutch pedal is also depressed to unload the drivetrain. The kickdown does all that automatically, in a fraction of a second.
V
VEW Offline
V Offline
My OD will disengage as soon as flip the switch to the solenoid off, and let off my accelerator. I'm then in 3rd gear.
~ Victor
Chaz 58 #1300074 02/21/2019 8:54 PM
V
VEW Offline
V Offline
Jerry, I read the thread "Overdrive electrical question" on this site which you contributed to and took your advise. I did use the Bosch type relay.
~ Victor
Chaz 58 #1300085 02/21/2019 10:07 PM
Deve's Technical Network had the exact wiring diagram I was looking for- http://devestechnet.com/Figures/bwwiring.pdf
