1 members (Steelonsteel),
141
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 74 | Hi,
Im looking to rejuvenate my suspension on my Chevy truck. Im planning on using my existing leaf springs, but would need shackle, etc. Any recommendation on what I should change or which is the best vendor for quality US parts.
| | | | | Joined: Jan 2019 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 74 | Has anyone had to rebuild their suspension? | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Wow, nobody has replied, sorry for that. In my opinion many people swap out their leaf springs in their 1/2 tons for no reason, They may see it sagging one side or another usually caused from worn shackles and hardware. I just recently went through my entire truck's suspension and disassembled the springs to clean and paint them, they are just fine. Bought some stuff from these guys and really like them alot.: https://www.classicparts.com/Chassis/products/143/Also like the Filling Station: https://www.fillingstation.com/ 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2019 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 74 | Thank you so much! Did you sandblast your springs before painting them? Which vendor did you like better, how come you used both, did one have other parts over the other?
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | When I got my truck, an inspection showed that one of the front shackles was broken and not holding the spring straight. So I replaced all the shackles and pivot points on both ends of the springs. Some of the ones that looked good were pretty worn once I got them apart. I left the springs alone, they seem okay, I know some people put a sheet product (cannot remember the name off hand) between the leafs when they go back together to help them slide across each other. Maybe something to look into.
Good luck.
Lee
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Teflon can be bought in bulk sheets on Ebay and cut to make sliders between the spring leaves. Jerry
| | | | | Joined: Jan 2019 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 74 | Thanks, does the teflon help a lot? Is it easy to take the springs apart and reassembe? What vendor did you get the shackles from?
Thanks! | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | I am planning to replace the rear springs on my 57 3100, what hardware is ok to reuse? I plan to get new u-bolts as I understand they stretch, but how do I determine if I need to replace shackles and associated hardware? Thanks! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If there is any looseness to amount to anything the shackels & pins & bushings will need replaced. Use 58-59 shackle kits. They have nuts on the end of the pins. Much better then the earlier ones. Unless you want complete originality. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
