3 members (BillyDon, Otto Skorzeny, 1 invisible), 90 guests, and 3 robots.
Topics128,180
Posts1,057,150
Members48,464
Page 163 of 177 1 2 … 161 162 163 164 165 … 176 177
back yard wrench turner
Cops and Cars for Kids show in Oviedo, FL. The kids love The Little Blue Truck books and my truck represents them well.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Got the paint going on the ring area of the third rim.
Mike B, looked really careful, and no L. So tried counterclockwise and got one nut, but others still frozen. Gonna hit em with more oil, soak time, and probably a bigger bar, 3/4 drive.
BIG CHEVY 3600, heat will be last resort as paint on nuts, studs and especially rims is in great condition.
But I'm always open to more ideas.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
This is my first post on this thread. Thought I would join in. Had my doors painted a couple weeks ago and now working on my box and bed.
1937 GC
I wrapped up the torque tube, rear differential , rear axle and rear brake overhaul and replacement project today. Now I need a couple helpers to lift this entire assembly off my bench and place on to the springs and under the frame of the truck. Any takers out there?
Bill Trotter (above) - I lived and worked in Iron River, MI as a trainee forester back in 1986-1988.Then moved to the big metropolis of Bergland, MI , then to Ironwood, MI. Nice pic.
1946 GMC Project
"Back-in-the-day Restore"
I really like the sign. Keep us updated on the progress.
~Jim
Very nice! Heck, I'd hang that in my living room!
I test fired my '51 panel today after a marathon cracked head replacement project. All seems well so far.
1951 Chevy Panel Truck
Socket Breaker
Socket Breaker
Last week: radiator was leaking in the '65 C10. took it out, went to my mechanic to try to find a radiator shop... found one, dropped it off the next day... picked it up a few days later, put it back in, did the dance with the anti-freeze and funnels.
Been trying to figure out which radiator I have... in case I had to buy a new one.
01/28/2019 - radiator: 9 pictures
Still not 100% on that, but at least this one is working good for now.
Oh yeah, a good tip: rubber gloves make dealing with anti-freeze soooo much easier.
old trucks are fun.
-Woog
Socket Breaker
Socket Breaker
Bill Trotter : those door signs look great.
Worked on my box today. Installed angle strips and cut quarter sawn White oak for the bed wood. Will figure out what and how to finish them.
1937 GC
If going "original" paint them black...prime with POR-15 and then top coat with POR Top Coat...you won't be disappointed. If you use a clear urethane or spar you'll be redoing it every few years because they just don't hold up now that they are water based...
I did put my new MD State permanent "Life Time" tag on the fire truck! Vehicle has to be 60 years old to qualify for this tag smile
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
MINWAX "Helmsman indoor/outdoor spar urethane is not water based. MINWAX does produce a polyurethane water based product sold as MINWAX Super Fast-Drying Polyurethane For Floors. I used the Minwax indoor/outdoor HELMSMAN clear semi-gloss spar urethane 8 years ago, applying 6 or 7 coats between light sanding with steel wool. The only change is a very slight darkening of the oak boards. Of course my 51 was not rebuilt as an original, and for that reason I would recommend Mike B's suggestion of black paint and POR-15 if that is your plan.
~Jim
Installed new seat covers. I bought a set from Jim Carters for a 41/46 to fit my '97 Chrysler mini van seat. I had my wife adjust them to fit.
Wayne
1989 Silverado
Heater blower motor stopped working. The fuse looked good so I was stumped. Bought a box of new ones (SFE 14) from O’ Reilly. Put in a new one and shazam, I’ve got heat now!!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Only if all our problems were fixed so easily
~Jim
Bought the material to redo the interior,that leather/tweed will be going soon and can not wait to get rid of it.
Picked up wheels and tires. going for maybe 1.5" drop in the rear with new springs
Installed rebuilt torque tube, rear axles with bearings and seals, turned drums, new carrier bearings, brake, lines and parts, NOS parking brake cables and made new parking brake rod, and installed new rear springs. Restored GMC gauge cluster with NOS gauges. This wasn't done just today - but occurred over an accumulation of days over the past month. 1941 GMC Next steps - put oil in rebuilt GMC 228, transmission, and rear differential and see if this thing will work...expecting many leaks.
1946 GMC Project
Very nice, Tom
Thanks for the reports.
Taking the interior apart to redo.
Got the 235 sat in the '40 chassis .
Have my wood stained and sealed. Ready to install in box when dry.
1937 GC
Dusty, got pics?
~Jim
Haven't done a darn thing for three weeks - snowed in, too cold in the garage. Long range forecast is for more of the same. Dude, where's that global warming they keep promising me?
Driveshaft in , other bits , throttle , choke , speedo cable , filled g/box oil , mounted exhaust , received parcel from RockAuto , (gaskets) mounted valve cover . Gonna start it tomorrow , dunno how to do pics .
pic ? OH ! cool , so that worked , ..... part way thru the job smile
Pair of nice projects.
Dusty, that is one beautiful garage.
~Jim
Don't hold your breath.
~Jim
It happens in our hemisphere every spring.
My completed bed
1937 GC
Beautiful bed Bill. You did a good job. Congrats!!
Chuck
1941 Chevy coupe
Just finished up on a 3.55 ring and pinion install on my 53 3100, plus all new bearings. Good bye 4.11
This truck just went 65 miles an hour. Very happy, smooth quiet gears and really pretty much an easy R&R.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Removing the cloth I put on all the metal interior panels,I will have to take all down to bare metal again to get paint to stick.
My completed bed
Now that's the ticket. Great job buddy ! ! !
~Jim
The odometer in the '62 C10 stopped working a few years ago. I took it apart a while ago to investigate and found a broken gear in the drive section. Since I didn't have the parts to fix it, I reassembled it and put it back in the truck. The Speedometer was still working so I was good with it.
Fast forward to a couple weeks ago when I was digging in the shed and found the old gauge cluster I took out when I converted to all gauges instead of Idiot Lights. I took it apart and Hurray! The gears in that speedometer were in good shape.
Today I pulled the cluster out of the truck and made a good speedometer/odometer out of the two of them.
It's nice to know how far I've travelled. Total cost? About an hour of my labor. I think I can afford that.
It was going to be such an easy job , LOL , famous last thoughts .
After a litany of complications , I finally finished the 216 > 235 swap . Goes great smile
Got some of the interior panels painted and installed,made new windlace for around the doors and covered the fiberglass headliner with dark brown newer style headliner material.
Completed a conversion to power front disc brakes on my ‘56. Used kit from
CCP. Not for amateurs; very fortunate to have had access to well equipped garage and tools (owner retired). Otherwise, the truck remains 100% original, but this was needed for safety while driving in an urban environment. Grabbed one of the under-dash mounts for the floor vent cables from a donor truck to mount on the driver side for the proportioning valve light... looks “store bought” original.
Also, replaced the steering sector with one from the same donor truck; can “feel” the road a little better. Cruzin down the interstate at 65 mph was just glorious!
Heater/Blower fan switch went out on the '62 C10 a couple of days ago. Had to jumper the connector to keep the defrost running. Needed that in the rain we've been having lately. New switch came in today. Already installed and working like a champ!
51-3100 How sweet it is...
