0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#1299320 02/17/2019 2:27 AM
Redoing the interior in my 37 and thinking about putting the original clutch head screws back in and wondering if they are still available and anyone know what size the screws are since I will need to find a tap and do not think I have one that small.
Yes, they are available. Jim Carter’s sells them, as do others. Don’t recall off hand the tap size, but from my experience one will make the reinstall process easier.
As 46Sparky stated Jim Carter has them. They are #8-32 and yes you want to chase the holes with the tap. They come with a black finish. I had purchased the Jim Carter powder coat for the interior of my '37 and had a local shop powder coat the interior pieces (29 of them ). I didn't want to install with black screws so I bought the cheap Harbor Freight powder coat system and used the left over powder to coat the screws. They came out real nice and blend in with the rest of the interior.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
what's the best way to get them out? I've tried drilling them and grinding them out. Most of them break or strip out
Its been so long since I first took it apart to remember how I got those screws out,I know I did not have the correct tools to do it.
Gert726 #1304312 03/23/2019 6:41 AM
Try a pencil point torch (search for butane torch on Amazon). A little heat helps a lot. Heat them up and use some penetrating oil.
They can be frustrating, and seemingly require magical four letter word string incantations to remove. They sometimes require a quality set of drill bits, and/or dremel tool with a cutoff disc, some might ease off with some penetrating oil. I think the pencil point torch idea would work too, but didn’t know about that option.
7
7 Offline
I had trouble with the clutch heads that secure the transmission/doghouse/ignition distributor covers on mine. I was able to work them all loose with heat and vise grips from the back side, enough of the threads protrude through the sheet metal to get the vise grips on. I know you won't have access to the back of all of your screws but do the ones you can get to.
Does any other application use clutch head hardware, or are they proprietary Chevrolet?
1951 Chevy Panel Truck
I've never had issue removing the clutch heat screws from my trucks using my clutch head screwdrivers. Maybe it's been pure luck.
Craig
The clutch head screws are also used on travel trailers.
Lots more pictures
They were non-proprietary to GM/Chevrolet - they were a product made by UNITED SCREW AND BOLT CORPORATION.
The "clutch head" rounded out on some of the screws when removing on my truck so I took a dremel tool with a cutoff wheel and made a screwdriver slot in the head. That and penetrating oil worked well. Good wrenching!
Ron - - Dusty53
1954 Chevy 3604
Moderated by  ndkid275, Phak1
