0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
Easy question. Having gone through my column and transmission, I dont recall a switch or circuit for backup lts. Before I broke the truck down, I had backup lts. Just dont recall where the switch contraption might reside. I have not installed the lts yet, but lost sleep last night, so it is time to ask the question.
~ HB
1962 Chevrolet C10
1962 Suburban
Back up light switch bolts on column near floor board and is actuated by a tap on the shift tube.
ESum
I do not remember that setup. I have an exploding view of the column. I will look there and also in the assembly manual. Is there a handy picture?
Thanks for giving me something to look for.
HB
~ HB
1962 Chevrolet C10
1962 Suburban
If you've got the Saginaw full-synchro 3 speed, I seem to remember some of them having a backup light switch incorporated into the side cover of the transmission.
Transmission does not have the switch. Is this the connection in the picture?
~ HB
1962 Chevrolet C10
1962 Suburban
That's a definite possibility. Try disconnecting the plug and putting a jumper wire across the wire harness connectors. The backup lights should come on if the circuit is good. With the column linkage in the reverse position there should be continuity between the connectors on the switch.
Yup that's it, sorry I have been busy helping goats birth kids.
ESum
Great thanks. Hope I got the tap bit right. I don’t recall that, but I will try to check voltage at the rear harness next time I think of it.
~ HB
1962 Chevrolet C10
1962 Suburban
