1 members (Rich'sToys), 68 guests, and 7 robots.
Topics128,021
Posts1,055,353
Members48,420
#1299132 02/15/2019 11:23 PM
Hello All, I have a “36” pickup & was wondering about putting insulation inside the doors to cut down on the outside noise & noise when the doors are shut; They sound very tinny when closing, preferably something that won’t be affected by rain water; Does anyone know of the best kind to get? Tnks for your advise. Richard
bebop40 #1299140 02/16/2019 12:02 AM
I have used this stuff which is a late model OEM type of stuff. You don't need full coverage. For example, on a door panel, about 1/3 coverage, right in the middle of the door, makes a HUGE difference in the tinny sound!
3M Sound Deadener
With that type of coverage, the price works out really good compared to those hot rod shops "Dynamat" stuff!
bebop40 #1299141 02/16/2019 12:05 AM
I sent Alvin a sample some time back, maybe has has used it and can chime in with his experience.
bebop40 #1299142 02/16/2019 12:08 AM
Moderator, Electrical Bay
Normally a pad of insulation was glued to the door skin and occasionally also to the inner side of the door facing the door skin. This stuff was about 1/4 inch thick and it was a mix of dense fiber paper like that used in egg cartons and tar. The pieces were cut by rule die cutters to the size needed. That's the best way I can describe it. I don't know where you'd get it today, although I did see where GM used a similar product as late as 1998 on a Pontiac I had to replace a window lift motor on. That product wasn't the same as the old stuff. It was more like tar paper but 1/8 inch or maybe 3.5mm thick. You probably could use 30 pound tar paper and laminate it using some waterproof construction adhesive (Liquid Nails Extreme). It isn't going to be any fun getting this installed in the inner door, though.
I would avoid any of the self-stick insulating stuff like MaxMat or anything resembling it. I doubt you'll be able to get your inside door clean enough for it to bond and the first time the sun hits your door it will come undone. Plus much of that stuff is just foil faced bubble wrap with a dual sided adhesive attached to it and sold at a nice profit.
If you could find a closed-cell foam (like neoprene) which was 1/8 inch thick, you could glue two layers of that to the inside of your doors and it might be easier to roll up and unroll once inside the door. I would not use anything thicker than 1/8 inch, though. Too hard to roll up. You could laminate that into 1/4" thickness by using two layers. Good luck.
~ Jon
bebop40 #1299162 02/16/2019 1:41 AM
Ok, Thanks guys, I appreciate the help.
bebop40 #1299460 02/18/2019 3:03 AM
I stuck dynamat extreme inside mine. No issues and very happy with the decreased noise.
bebop40 #1299584 02/19/2019 1:41 AM
Mark, I have it laying on the seat of the coupe. I haven't forgot it but can't report on it. I think it'll do the trick but it will be maybe another month when its warmer. (I've been very busy with some other matters....in addition to the rain/cold.)
