5 members (Otto Skorzeny, Samantha, Hotrod Lincoln, Ricks Big Dump, Hanks custodian), 164 guests, and 1 robot.
Topics128,081
Posts1,056,073
Members48,434
#1298046 02/08/2019 5:03 PM
Hey guys, need to know the cruising RPM for my 1954 3600. Put larger tires on so my speedo is way off. Put a tach on and I can get my speed off my GPS (TOMTOM). Also what would redline RPM be? Thanks.
KEV BB FARMS #1298050 02/08/2019 5:23 PM
As I said in your other post is what type of transmission are you running? Are there speedometer adapters available for it? I'm running a SM420 and got a speedometer adapter since I changed the rear end gears. With my 3.55 gears, I cruise at 60+ running at 2200 rpm.
Craig
KEV BB FARMS #1298060 02/08/2019 5:55 PM
Trans is stock 1954.
KEV BB FARMS #1298068 02/08/2019 6:47 PM
2 Offline
if it helps answer your redline question, i've attached an image of a typical power curve from a chevy engine test report for a 235 cu
this image is from 1948 publication
i've been told not to run 235s beyond 4000 rpm as that's "destruction in minutes" territory, but could be wrong or not remembering correctly.
-s
KEV BB FARMS #1298072 02/08/2019 7:15 PM
Just for the heck to of it, here are power curve graphs for 1954 235 and 261 trucks (high-pressure engines).
Improved versions of earlier engines, and compared to engine/graph posted above.
http://chevy.oldcarmanualproject.com/chevyresto/54143.htm
http://chevy.oldcarmanualproject.com/chevyresto/54146.htm
These are available for later 235/261 engines, with higher compression heads, etc.
KEV BB FARMS #1298073 02/08/2019 7:23 PM
RPM = MPH × Final drive ratio ÷ Tire OD ÷ .002975
To get an answer, you need data on those three.
I've read references to 4,000 as the upper limit, but there are several possible reasons:
1. valve float - the intake valve will strike the piston (but should occur higher than 4K)
2. with the splash oil system reliable delivery to the rods is decreased by chaos in the pan
3. refers to iron pistons? Lots of weight flying around on that skinny rod
4. 2,500 f/m piston speed is an industry recco for sustained speed, it's 3,810 RPM for that stroke length
KEV BB FARMS #1298151 02/09/2019 4:32 AM
H Online: Content
Assuming you've got an original-equipment engine and drivetrain, I'd suggest a max cruise RPM of around 3000, assuming the lower end is in very good condition and the oil pressure is good. Be aware that the engine will be a little noisy, mostly from the fan being wound up pretty tight. The 54 235 engine should have aluminum pistons and insert-type rod bearings, so pounding Babbit bearings out with cast iron boat anchors shouldn't be a problem. Short runs above 3K shouldn't do much damage, but most folks just can't bring themselves to run a stovebolt that fast.
Back in my college days, I ran a 58 Chevy Delray coupe with a 235 regularly at 70+ MPH with a 3 speed and a 3.70 rear end, and 14" wheels. Yes, it sounded a little stressed, but it stayed together for a long time.
KEV BB FARMS #1298185 02/09/2019 3:34 PM
1954 3106 Suburban:
261 with 3.55 rear end, and 31.5" rolling-diameter tires.
My MPG at constant speed highway driving (approx. 60-62 mph) is approx, 18 mpg - at approx. 2300 RPM
I see the gas mileage decrease significantly as I increase speed (getting around 12 mpg at approx. 66-68 mph, 2600 rpm).
I will not post how fast I have driven the truck, but it starts getting "squirrely" (wandering) at around 75 mph.
KEV BB FARMS #1298188 02/09/2019 3:41 PM
If you have original equipment: 1954 3600 (3/4 ton)
4.57 standard rear end (5.14 was optional)
approximately 28" to 31" rolling diameter of the wheels (depending on equipment)
approximately 3300 RPM at 60 mph
RPM calculator
KEV BB FARMS #1298272 02/10/2019 1:22 AM
Power system coming on, or vacuum advance backing off?
KEV BB FARMS #1298343 02/10/2019 4:37 PM
Took truck out yesterday and hit the back roads. Cruising at 60 engine was at about 2800 RPM's. Tire size is 235/85/R16. Main concern is if the engine can handle these RPM's for an extended time. Truck is all stock 1954 Chevy 3600 with a 4 on the floor trans. Thanks.
KEV BB FARMS #1298347 02/10/2019 5:06 PM
H Online: Content
Only about 3 days past forever! These engines were designed to run wide open for hours at a time in the big rigs, pulling full (or way over) maximum gross weight loads. It's only been a recent trend for snowflakes with lace on their drawers to get a case of the vapors when they hear an engine turning RPM's even a little above idle speed. For the past 2-3 decades, manufacturers have been putting high rear end gear ratios and overdrive transmissions in their vehicles, and running engines at just above idle on the highway. My 04 Dodge Ram 1500 is only running 2,000 RPM at 75 MPH! Jump on that loud pedal and enjoy listening to an engine actually earn its keep for a change!
KEV BB FARMS #1298350 02/10/2019 5:28 PM
BEST REPLY EVER !!!!!!!!!!!!!!!!! I'm all about letting it rip. But I just want someone to blame when it blows up !!!! LOL.
KEV BB FARMS #1298361 02/10/2019 6:48 PM
A 55-62 motor can take more then 4000 rpm. Heck, the mechanical advance is not all in until 3500 rpm but yes, the springs would be a limiting factor. With good springs, or double springs, a 55-62 235 motor can go to at least 5200-5500 and I have one motor still in the back of my garage that I ran into those numbers on a regular basis on the street and race track, and once or twice into the 6000 range for 25 years. The issue in those rpm ranges is that the head really does not breath much past 4800 or so even in modified form, and probably not that deep in pure stock form, and it gets a little squirrelly when you are in the 5500 and up range with those rods. That and the harmonics start to play a part over 5000 rpm (read that loose flywheel bolts for example). So really your best bet is to keep rpms under 5000 rpm, but yes, no real problem 4000-4500.
Mike
KEV BB FARMS #1298381 02/10/2019 9:39 PM
What do you suppose the gas mileage might be at 4000-4500 RPM?
What is the impact of wind resistance on our aerodynamic trucks at 95 mph?
KEV BB FARMS #1298382 02/10/2019 9:44 PM
If those engines couldn't take long hours of heavy load + high speed they wouldn't have installed them in trucks.
KEV BB FARMS #1298402 02/10/2019 11:21 PM
Moderator, Electrical Bay
Hi Tim,
I don't believe there will be any gas mileage to discuss at that rpm, but I also don't think it will hurt the engine as much as some do. After all, running the engine at that speed you will be pulling off the highway at every exit to refill the fuel and oil tanks (not to overlook refilling the radiator and allowing it to cool down) so your engine should enjoy a nice rest period while that's happening.
The impact of wind resistance at 95? Seems to me it would be secondary to the problem of safely steering and stopping one of these trucks at that speed.
~ Jon
KEV BB FARMS #1298414 02/11/2019 12:10 AM
Thanks for the reply, Jon
and, Amen on gas mileage, steering, stopping and safety - on a stock truck.
I got my Suburban up to 93 ONCE.
It was an insane action - but, I wanted to prove that I could do it – and, the road was empty/safe.
I was showing off for my young mechanic-friend.
I asked him to check his pants after we slowed down.
Never again . . .
KEV BB FARMS #1298428 02/11/2019 1:22 AM
Thank you Gentlemen. You have answered my question with flying colors. NOW GET OUT OF MY WAY I'M COMING THRU AND I CAN'T STOP LET ALONE STEER !!!!
KEV BB FARMS #1298565 02/12/2019 12:08 AM
I had the opportunity about a year ago due solely to my own fault to have to drive a 650 mile day home from the stove bolt get together .
By coincidence it was the same distance to the event the only difference being I had an over drive gear that kept the rpm on my stock 62 235 at around 2200 rpm. at 70 mph.
the trip home with no overdrive had me traveling at around 60 mph give or take and a fairly constant 3000 rpm. The only difference I noticed is that it pulled up the hills without lose of speed or the need to downshift. The truck weighs in at about 6000 lbs, and has the aerodynamics of and apartment building . I check mpg with every fill up and fuel mileage remained the same at 14 mpg. in both directions. Both trips were done none stop other then many MANY stops for gas.
I noticed no difference in temp. oil consumption or engine noise.
That being said I will be returning this april. along with new overdrive gears.
good planning is no substitute for dumb luck
KEV BB FARMS #1298972 02/14/2019 7:07 PM
Safe cruising RPM is something I have wondered lately as well, since I am about to install a fresh rebuilt 261 into my 53 1/2 ton. I was curious to the max cruise speed that these engines can handle. I figured 55-60 mph would put the engine in the 2,500-3,000 rpm range, which might be a fast as I would comfortably run one for a 10+ mile trip. My truck is stock configuration and the furthest trip I ever foresee making in it is a one-way highway trip of about 85 miles. I know "in theory" my truck will run up past 80 mph and 5,000 rpms if pushed to the max, but at what RPM do these engines enter the "danger zone" pertaining to lubrication, etc when run for an extended period of time?
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
KEV BB FARMS #1298976 02/14/2019 7:29 PM
H Online: Content
Looking at the factory maximum HP ratings of several mid-1950's 235's, they're specified at 3700-4200 RPM for various year models and transmission/rear end combinations. Since the 261 has the same stroke as a 235, similar figures would probably apply. I don't have 261 factory specifications handy at the moment. A 261's big advantage over a 235 is increased torque, not a lot more top end horsepower. Above those speeds, HP begins to drop off pretty dramatically as the "curve" goes above maximum. Torque tops out about 2000 RPM for most applications, so the "safe" operating range for best performance seems to be in the 2K-4K speed range. 4500-4800 won't hurt it- - - -but you're just spitting into the wind, power-wise.
While it's possible to make a stovebolt engine run above 4K RPM, it seems to be pretty pointless unless modifications such as camshaft changes and cylinder head and valve upgrades are done to move the HP curve to a higher RPM range. Then you end up with an engine that loses massive amounts of torque and pulling power in pursuit of a rather mediocre HP gain.
KEV BB FARMS #1298988 02/14/2019 9:35 PM
Hi Patrick. You can get a slew of opinions on this subject. Here's mine: They cruise well and economically at 2000~2300 rpm...smoothly and effortlessly as long as you're on relatively flat roads and not in a headwind. At 2500 to 3000 rpm, you can drive your engine all day long but gas mileage will decline steadily the closer to 3000 you get. Trust your ears and your sense of feel. There is a big difference in driving one of these engines at 3000 to 3500 rpm versus driving a Honda, Subaru, Toyota engine at 3500 rpm. The harmonics are altogether different.
I had an uncle who was a cotton farmer. His analysis of the 235 (very similar to yours) was "run these at the right rpm and you can depend on them almost forever. Run these too hard and fast and you can depend on them for a little while. It is your choice." He used them to run irrigation pumps and some of his were still going after almost 20 years the last time I saw them.
~ Jon
KEV BB FARMS #1299032 02/15/2019 3:01 AM
I plan on running my truck at a max speed of 55mph, so I don't think max RPM's will be an issue for me!
-Patrick
1953 Chevrolet 3100
KEV BB FARMS #1299040 02/15/2019 4:00 AM
That's a wise decision from several standpoints. Hope you enjoy the 261.
~ Jon
KEV BB FARMS #1301534 03/03/2019 2:57 PM
I run my '46 with a '54 235 / 3:55 gears and 16x7.00 tires at about 60-62 on the highway. Engine now has over 80,000 on it since it was rebuilt in 1986. It'll go faster, but you can tell she don't like it. You can feel when you're pushing them too hard. Also, it almost goes without saying that regular maintenance is key, and not using motor oil made for modern car engines. Been using Valvoline oil for diesels forever and not a hint of smoking or oil burning (of course it leaks some, but that's a feature, not a bug).
KEV BB FARMS #1301540 03/03/2019 4:11 PM
It is all well and good to say the speed that you will run it and I think yours is a wise choice if everything else is stock. In my case my 54 has 2.73 gears, I have on many trips said that I will run at 55 mph but when the traffic around me is running 65-70 I soon find that I am running at the traffic speeds. Good luck.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
KEV BB FARMS #1301542 03/03/2019 4:28 PM
H Online: Content
Back when I was using a 1959 3800 like a truck, not a pampered toy, I could cruise the slow lane of the interstate at around 60 MPH with no problems. That rig had a 4.56 rear end and 18" tube type tires. Yes, the engine made some noise, but it didn't hand grenade, and I drove it that way on a regular basis. The 58 Chevy Delray coupe that I drove in college in the mid-1960's, with a 235 3 speed setup, a 3.70 rear end, and 14" tires had no problem running 70 MPH or more virtually every time I drove home, 150 miles each way.
