| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 177 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 177 | Every time I head towards my grandfather's farm I see 2 or 3 old AD trucks. Flat beds.
Compared to the 3100, how do they differ as far as sheet metal? Track width wider? Same cabs? | | | | | Joined: Aug 2018 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2018 Posts: 28 | I've been told the cabs are the same. I have a '54 4400 and was told the fenders are a little wider on mine versus a 3100. I have never actually measured and compared so just going by what I have been told.
1954 Chevy 4400
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Cabs are the same. Fenders, hood, grill, and related parts are same for 1/2 ton, 3/4 ton, and 1 ton. Short running boards are same for these trucks too Fenders, hood, grill, and related parts are same for 1.5 and 2 ton. 2 ton is a little wider front track width than the smaller trucks. I believe that 3/4 and 1 ton are same and wider than 1/2 ton by a tiny bit. Plenty of dimensions like these in the shop manuals and "restoration packs" GM once sent out for each year if you asked http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0202.htmhttp://chevy.oldcarmanualproject.com/chevyresto/index.htm | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you want to drive them, look at running gear, wheel bolt pattern, braking system.
Ed
