0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
I have a 1958 v code step side. It has an original 283. Shifting from 2 to 3 the rod does not go all the way into 3rd. At the transmission the 2nd 3rd rod buts up against the reverse, first plate that holds the 1st, reverse rod. The transmission will go into reverse first and 2nd. The transmission was rebuilt is there anyway to put the shift shafts in the wrong location, or is this just miss adjusted.
Riding in the Passing Lane
I wonder if one or the shift levers is backward. Like upside down.
George
1972 Chevy c10 Cheyenne Super
They are only keyed on the top. The "key" is where the bolt goes through. This means the rods connect on the bottom of the levers.
If the levers are curved is it possible one is flipped over.
Is it possible the rebuilder put the wrong side cover on it?
ESum
I want to say that we had this issue with a truck at homecoming. If I remember correctly, we bent the rod very slightly to get the rod to clear. After that Jim’s truck shifted great.
Chris
Take a look at the shift levers on the side cover. Both levers should be facing outward, with the bolt to the inside. If the installer turned one or both around it could be the cause of the problem. The correct side cover should have the short shaft to the front with the long shaft to the rear. Both levers should point down and slightly forward and facing outward. If everything looks OK it could be a simple adjustment of the rods.
Fred
