7 members (Gdads51, TUTS 59, WICruiser, Phak1, Wheelie, Bill Hanlon, 1955 1 Series),
101
Mod | | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | I have a 1958 v code step side. It has an original 283. Shifting from 2 to 3 the rod does not go all the way into 3rd. At the transmission the 2nd 3rd rod buts up against the reverse, first plate that holds the 1st, reverse rod. The transmission will go into reverse first and 2nd. The transmission was rebuilt is there anyway to put the shift shafts in the wrong location, or is this just miss adjusted. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I wonder if one or the shift levers is backward. Like upside down. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | They are only keyed on the top. The "key" is where the bolt goes through. This means the rods connect on the bottom of the levers. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the levers are curved is it possible one is flipped over. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | Is it possible the rebuilder put the wrong side cover on it?
ESum
| | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | I want to say that we had this issue with a truck at homecoming. If I remember correctly, we bent the rod very slightly to get the rod to clear. After that Jim’s truck shifted great.
Chris | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Take a look at the shift levers on the side cover. Both levers should be facing outward, with the bolt to the inside. If the installer turned one or both around it could be the cause of the problem. The correct side cover should have the short shaft to the front with the long shaft to the rear. Both levers should point down and slightly forward and facing outward. If everything looks OK it could be a simple adjustment of the rods. Fred
