5 members (Gray_Ghost, GMCJammer51, Otto Skorzeny, Paul Mullen, Jon G), 172 guests, and 5 robots.
Topics128,078
Posts1,056,046
Members48,433
#1297594 02/05/2019 12:19 AM
Hi,
Im looking to rejuvenate my suspension on my Chevy truck. Im planning on using my existing leaf springs, but would need shackle, etc. Any recommendation on what I should change or which is the best vendor for quality US parts.
Has anyone had to rebuild their suspension?
Wow, nobody has replied, sorry for that.
In my opinion many people swap out their leaf springs in their 1/2 tons for no reason, They may see it sagging one side or another usually caused from worn shackles and hardware. I just recently went through my entire truck's suspension and disassembled the springs to clean and paint them, they are just fine.
Bought some stuff from these guys and really like them alot.:
https://www.classicparts.com/Chassis/products/143/
Also like the Filling Station:
https://www.fillingstation.com/
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Thank you so much! Did you sandblast your springs before painting them? Which vendor did you like better, how come you used both, did one have other parts over the other?
When I got my truck, an inspection showed that one of the front shackles was broken and not holding the spring straight. So I replaced all the shackles and pivot points on both ends of the springs. Some of the ones that looked good were pretty worn once I got them apart. I left the springs alone, they seem okay, I know some people put a sheet product (cannot remember the name off hand) between the leafs when they go back together to help them slide across each other. Maybe something to look into.
Good luck.
Lee
1956 Chevy 3200, 235 w/3 speed
Teflon can be bought in bulk sheets on Ebay and cut to make sliders between the spring leaves.
Thanks, does the teflon help a lot? Is it easy to take the springs apart and reassembe? What vendor did you get the shackles from?
Thanks!
I am planning to replace the rear springs on my 57 3100, what hardware is ok to reuse? I plan to get new u-bolts as I understand they stretch, but how do I determine if I need to replace shackles and associated hardware? Thanks!
Riding in the Passing Lane
If there is any looseness to amount to anything the shackels & pins & bushings will need replaced. Use 58-59 shackle kits. They have nuts on the end of the pins. Much better then the earlier ones. Unless you want complete originality.
George
1972 Chevy c10 Cheyenne Super
