4 members (DadsFirstPickup, Otto Skorzeny, 1955 1 Series, 1 invisible), 46 guests, and 4 robots.
Topics128,089
Posts1,056,366
Members48,442
#1297901 02/07/2019 10:57 AM
Hey guys,
Just curious if anyone knows what the widest back tire I can use without changing rear fenders or bed in my 1950 3600. I'm trying to get this chassis rolling and don't have the sheet metal to go off of. Using the ford 8.8 rear end which h measure out the same as the 3100 stock rear.
I tried searching but I'm getting a few different numbers. I think I'm gonna stick with 26 tall.
Any info is greatly appreciated.
I had a 245/70/16 on mine at one time with no issues. I've seen some say that 255 is the widest without having some rubbing issues.. I think it all depends on how low you go, and the tire itself. Different tires have different tire bulge, etc... If your truck doesn't have a bunch of lean in the corners and not alot of axle flex, you could probably get a little wider in, but it would have to be perfectly centered.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Hmm, yah I'm not sure about the different variables since it's on jack stands at the moment. Sounds like it would be best to buy some junk yard rims and tires until to mock it up and take measurements
