| | | Forums66 Topics128,111 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 46 | Hey guys,
Just curious if anyone knows what the widest back tire I can use without changing rear fenders or bed in my 1950 3600. I'm trying to get this chassis rolling and don't have the sheet metal to go off of. Using the ford 8.8 rear end which h measure out the same as the 3100 stock rear.
I tried searching but I'm getting a few different numbers. I think I'm gonna stick with 26 tall.
Any info is greatly appreciated. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I had a 245/70/16 on mine at one time with no issues. I've seen some say that 255 is the widest without having some rubbing issues.. I think it all depends on how low you go, and the tire itself. Different tires have different tire bulge, etc... If your truck doesn't have a bunch of lean in the corners and not alot of axle flex, you could probably get a little wider in, but it would have to be perfectly centered. | | | | | Joined: Jan 2019 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 46 | Hmm, yah I'm not sure about the different variables since it's on jack stands at the moment. Sounds like it would be best to buy some junk yard rims and tires until to mock it up and take measurements | | |
