Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (TexasFarmTruck, Mike1933), 189 guests, and 7 robots.
Topics128,282
Posts1,058,496
Members48,490
#129770 10/07/2005 11:07 PM
I have removed the front clip, motor & trans now its time for the hard part. any help whould be appreciated (I have 1964 v8 motor mounts)
#129771 10/08/2005 9:28 PM
Riding in the Passing Lane
Are you changing from a 6 cyl.?
1972 Chevy c10 Cheyenne Super
#129772 10/09/2005 12:10 PM
yes, going with 350& 350 trans. I found a front mount yesterday off a 62 will use that as a guide for side mounts. Now i need to figure out how to mount trans.
#129773 10/10/2005 10:57 PM
If you are going to an automatic you will have to remove or modify the crossmember behind the engine. Than ad a crossmember at the rear of the trans. You can buy one or fabricate one.
#129774 10/10/2005 11:24 PM
Z
Z Offline
I used a 99 350 Vortec EFI/TH400 in my '51, I wish I had gone with the 700R4, for a daily driver it needs the overdrive. It has a 3:42 rear and the rpm's would be lower. But it does move. Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#129775 10/12/2005 12:54 AM
Thanks for tips Wrenchbender i have removed crossmember now fabricating new one out of angle iron any thoughts on this? Zerker6, 350 trans was a freebie hope i dont regret it. Maybe i will change rear down the road
#129776 10/12/2005 11:40 PM
I rtealize it isnt too bad of a job to fabricate new crossmembers for tranny mounts.But you can buy them fairly reasonable from the parts houses,Brothers,Chevy Duty,Golden State,etc.There is also a nice motor mount setup,that fits in bretween the frame and is a very easy instalation.I cant remember which place I got mine from.It uses the standard small block motor mounts.Saves a lot of work.
#129777 10/15/2005 6:57 AM
Crossmembers are usually made from channel or tube and not angle iron. You'll want to make sure its going to handle the stress. Angle iron does bend.
#129778 10/26/2005 4:35 AM
9
Junior Member
Junior Member
9 Offline
you should be able to take the trannt cross-member and motor pads to front cross member, out of any 60-73 v8 auto truck. Try a salvage yard close to you, 73+ might work too. You might have to knock out some rivets,but just use bolts to reinstall. GM was good to us these frames stayed relitivly the same for all these body styles. Even the coil sprung frames have all the same hardware holes.
