8 members (J Lucas, Hotrod Lincoln, dt235sd, 1955 1 Series, Gdads51, 55shaker, Lightholder's Dad, wilbur53),
81
Mod | | | Forums66 Topics128,079 Posts1,056,297 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | Good afternoon
I'm trying to figure out if adhesive/sealant is required between the rubber gaskets and the metal edge of the corner windows, back window and front window. I've searched here and looked in my manuals with no luck. Still fighting with the door window sweeps, but that's an entirely different problem! As usual 1 step forward-2 (sometimes 4) steps back!
Thanks Jeff 1948 3100 Deluxe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | The bead which is inserted into the seal puts enough pressure on the seal to make it as waterproof as a frog's butt.
| | | | | Joined: May 2015 Posts: 11,082 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,082 | as waterproof as a frog's butt. I was always pretty sure a duck's butt was waterproof, as they don't sink, but frogs don't float as well as ducks do.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | Excellent! Thanks so much for the answers, just what I was hoping for! Even the frog's butt was a great analogy ! Thanks again Jeff | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | I was going to use a turtle's butt, except that some turtles, such as snapping turtles, actually allow water to enter that orifice as another means of extraction oxygen from the water. As far as ducks go, I don't like them. They are fowl...
