1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
Good afternoon
I'm trying to figure out if adhesive/sealant is required between the rubber gaskets and the metal edge of the corner windows, back window and front window.
I've searched here and looked in my manuals with no luck. Still fighting with the door window sweeps, but that's an entirely different problem! As usual 1 step forward-2 (sometimes 4) steps back!
Jeff
1948 3100 Deluxe
The bead which is inserted into the seal puts enough pressure on the seal to make it as waterproof as a frog's butt.
I was always pretty sure a duck's butt was waterproof, as they don't sink, but frogs don't float as well as ducks do. eeeek
Excellent! Thanks so much for the answers, just what I was hoping for! Even the frog's butt was a great analogy !
Thanks again
Jeff
I was going to use a turtle's butt, except that some turtles, such as snapping turtles, actually allow water to enter that orifice as another means of extraction oxygen from the water.
As far as ducks go, I don't like them. They are fowl...
Moderated by  ndkid275, Phak1
