Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#1297322 02/02/2019 9:27 PM
hi,
i'm working on a 1951 3100 panel with a 1957 235 4 spd.
when the motor was rebuilt, the rebuilder tapped the crank and added a big [censored] bolt and washer to help secure the harmonic balancer. i need the low clearance water pump and the fan is now hitting the balancer bolt.
my understanding is that the harmonic balancer is pressed on and this bolt was added as a back up should the balancer come loose. so do i even need this bolt?
if i do need it, i only have 2" of clearance between the water pump and the rad. is there a electric fan that i can use? if so, can it be mounted in front of the rad?
thanks.
doobspanel #1297333 02/02/2019 10:31 PM
Use a flat-head Allen bolt with a tapered head in the crankshaft and taper the hole in the washer. It will eliminate the bolt head sticking out. A better fix is to use Pre-68 Dave's water pump relocation plate that adapts the 216-style water pump to the later engine, raises the fan about 3 inches, and also centers the fan on the radiator for proper cooling. Electric fans are a solution to a nonexistent problem when the right fix is simple, easy, and much more effective.
doobspanel #1297389 02/03/2019 4:50 AM
Fox Offline
I have Dave’s adaptor plate on my 261 in my 50 AD and it works. Stock rad, alternator setup, 216 pump. It was easy. I second Jerry’s advice.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
doobspanel #1297402 02/03/2019 1:26 PM
I am another happy camper with Dave's water pump adapter plate
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
doobspanel #1297669 02/05/2019 6:14 PM
thanks guys, i'm trying to find dave's i know of a deve's that makes a PCV kit. is that the same guy?
if not, do you have a link?
if that moves the fan enough to insert the bolt, great but...if it dosen't, do i need to figure a way to make it work like jerry suggested or can i live without it?
thanks
doobspanel #1297673 02/05/2019 6:25 PM
His Stovebolt handle is Pre68Dave. Not the same guy as deve.
doobspanel #1297680 02/05/2019 7:20 PM
doobspanel #1297722 02/06/2019 2:40 AM
Your builder installed the bolt for a reason. I had a pressed on balancer come off at high rpm once, it was not pretty. Can you picture a balancer shaped hole in the side of an early corvette? Use Jerry's suggestion.
