11 members (1955 1 Series, 2-Ton, Robert Crandall, Gdads51, 52Carl, fonz8261, greenie-reddy, Forty9, RoadsScholar, mk72, 1 invisible), 129 guests, and 1 robot.
Topics128,125
Posts1,056,343
Members48,441
#1297237 02/02/2019 3:29 AM
I appreciate being accepted as a member to the Stovebolt site. I currently have two projects. 1957 SWB 3100 and a 1965 C10 LWB, both are step sides. I have owned these trucks for approximately 8 years and had just been gathering original parts and educating myself. I have recently retired and will be jumping into the restoration process for the 1965 first. Just so happens my former bother in law tells me the 65 C10 is the exact style, color and year truck my grandfather once owned. The 1957 truck has the 3 speed manual transmission with overdrive, and believe it or not, I found this in a storage barn that I could see from my house and never new the truck was there. I will be restoring the vehicles to their original state. I have learned so much from just reading the posts on this site. I will have many questions going forward. Thanks in advance.
1957 3100 - 1965 C10
~Brian
Welcome to the Stovebolt. Your a lucky man to have found an actual barn find these days. Congratulations.
We are all here to help with your questions.....just remember to ask them in the garage forum that best fits the question. Take some time, look at the gallery, read the tech tips. There is tons of knowledge here and guys, and gals, willing to share it with you. Good luck and see you around the garage.
Moderator, Great Lakes Bolters
1 Offline
SmalltownTRKGuy,
Welcome from another Michigander!
Hoping we can have some Stovebolt gatherings this Spring/Summer in the Mitten State, so check in to the "The Great Lakes Bolters" section.
--Tom
Welcome to the Stovebolt madness. There is no cure! Don’t want to jump right on the new guy but eventually someone will concerning your description of your trucks. LWB and SWB are designators for wide beds not step sides. Most on here just call them stepsides but for years I’ve heard the designation LNB and SNB. Now that we’ve got that bit of housekeeping out of the way what are your plans. Restoration or Restomod? Either way you’ll be welcome here.
shake
welcome to the 'bolt.
Please scroll through the various forums to see what they have to offer.
Make sure to check out the rules of the page as well.
Questions pertaining to your problem are welcome and will usually get answered quickly.
There are many "how I done it's" here as well that can be found using the search feature.
Another quality post.
Real Trucks Rattle
Smalltown Trucker
Welcome aboard! Martin is correct--There is no cure!
You are a man after my own heart! I currently restoring my 57 3100 which may be done this year! I have owned it since 1969 & it was dd for many years. Until I went modern & got a 72 GMC 4wd in 1980!
First vehicle I ever drove was a 65 K-10 -- so we have alot in common!
Again, Welcome aboard.
delky dave in WYO
1957, 3100, v8
2016 gmc 4wd
Thanks for the warm welcome, learning already. What was intended was that my 1957 has a short wheel base, and my 1965 has a long wheel base. I plan to take them back to their original state. A lot of very good information here and it is greatly appreciated. Look forward to the Great Lakes Bolters also. Stay Warm!!
~Brian
~Brian
