0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I have a vacuum leak on my manifold so I'm removing it to take a look. I believe it was a little warped when I installed it but thought the gasket would make up for it. I also didn't install alignment rings. I'm worried that if I split the manifold to install a new gasket I will break a bolt(s) & these things are hard to find. I would value anyone's recommendations.
1958 Chevy Grumman Olson step van
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Make and year and size engine? | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | 1958 Chevy Grumman step van 1960 261.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to try this REMFLEX gasket. It is much thicker compared to the original gasket (beside being one-piece; and, being easier to install). I had a 54/55 GMC COE, and I understand your reticence in messing around with the manifold assembly. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | The machine shop where I ran the connecting rod reconditioning department for a few years had a BIG belt sander (like 18" wide and 48" long). We could even up the gasket surfaces on an inline intake/exhaust assembly on that one without unbolting the two pieces. Look around for an oldtime auto machine shop- - - -those sanders used to be very popular for surfacing cylinder heads, also. Jerry
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | It's also almost impossible to install a manifold assembly without alignment rings and avoid a vacuum leak. If you don't have the OEM rings, a piece of exhaust tubing with a slot cut into it can be trimmed to the correct length so it fits the hole in the head or manifold correctly. The slot doesn't even have to be welded- - - -it just aligns the head and manifold- - - -the gasket is what does the sealing. Jerry
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | The rings helped. I was unable to get the front manifold bolt in, probably from being warped. Anything I can do to get the bolt in?
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | The front and rear holes in the manifold didn't have bolts originally- - - -just an unthreaded stud sticking out of the head to align the ends. You might try enlarging the hole in the manifold a little with a die grinder or a rat tail file if you decide to bolt them instead. Jerry
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Hard to believe how much better the engine runs. Thanks guys!
