3 members (Otto Skorzeny, carbking, baldeagle), 110 guests, and 2 robots.
Topics128,037
Posts1,055,468
Members48,424
#1295237 01/18/2019 2:08 AM
I have a vacuum leak on my manifold so I'm removing it to take a look. I believe it was a little warped when I installed it but thought the gasket would make up for it. I also didn't install alignment rings. I'm worried that if I split the manifold to install a new gasket I will break a bolt(s) & these things are hard to find. I would value anyone's recommendations.
1958 Chevy Grumman Olson step van
Make and year and size engine?
1958 Chevy Grumman step van 1960 261.
You might want to try this REMFLEX gasket.
It is much thicker compared to the original gasket (beside being one-piece; and, being easier to install).
I had a 54/55 GMC COE, and I understand your reticence in messing around with the manifold assembly.
The machine shop where I ran the connecting rod reconditioning department for a few years had a BIG belt sander (like 18" wide and 48" long). We could even up the gasket surfaces on an inline intake/exhaust assembly on that one without unbolting the two pieces. Look around for an oldtime auto machine shop- - - -those sanders used to be very popular for surfacing cylinder heads, also.
It's also almost impossible to install a manifold assembly without alignment rings and avoid a vacuum leak. If you don't have the OEM rings, a piece of exhaust tubing with a slot cut into it can be trimmed to the correct length so it fits the hole in the head or manifold correctly. The slot doesn't even have to be welded- - - -it just aligns the head and manifold- - - -the gasket is what does the sealing.
The rings helped. I was unable to get the front manifold bolt in, probably from being warped. Anything I can do to get the bolt in?
The front and rear holes in the manifold didn't have bolts originally- - - -just an unthreaded stud sticking out of the head to align the ends. You might try enlarging the hole in the manifold a little with a die grinder or a rat tail file if you decide to bolt them instead.
Hard to believe how much better the engine runs. Thanks guys!
