2 members (Tinker5, klhansen),
178
Mod | | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Just received my non-dimpled pedal shaft bushings from Jim Carter, very disappointed. I have TWO spare pedal assemblies and on BOTH the bushings are VERY loose test-fitted on each of those shafts.
Will the bushings reduce in size when press fitted into the pedal arms thereby making the fit on the shafts closer? I just can't see going to all that bother to end up with little to no improvement.
I've been thinking of sending them off to a brake master cylinder resleever to have it done. I do hope a few suggestions come forward.
Thanks!
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | They will shrink some if actually a press fit in the part. Thin bushings shrink almost as much in the bore as the press fit interference is in the part. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | What kind condition is the shaft in? Worn?
| | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Carl, both spare pedal assembly shafts have slight wear. I don't have a micrometer but I do have a vernier caliper. I will take three readings each, average and compare. I will also do that with the third shaft, that which is on the truck at this moment. Grigg has noted in the past that the shaft is hardened steel, the bushings, softer brass and by design, replaceable.
The present Clutch & Brake pedal assembly has the wear of my personally driven 112,000 miles in addition to the 'who knows how many' miles of the previous owners. Next get-together, probably at Homecoming I will note the differences between trucks. Right now they (the two bushings) are very loose and wobbly, so much so that my brake pedal can get hung up on the toe board.
| | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | I just replaced the bushings on my 46 2 ton, and got mine from classic parts. Jim Carter was out of them last month when I tried ordering. These fit fine, and actually had to hone just a bit on the clutch pedal after installing the bushing, but was good on the brake pedal. Maybe a different supplier? I know when I called Carter the told me it would be at least 4 weeks before they would have them in stock.
Kevin Kevin
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Cosmo, I have a few extra pedal shafts in my giant pile of unthowawayable parts, I'll bring them to Homecoming if I find that they are in good condition. All I ask in return is for you to represent me should I run into major controversy, real or imagined by the Council. It is rumored that you have pull in these matters. Carl
