2 members (JW51, 78buckshot), 86 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#1296931 01/30/2019 8:56 PM
Hi all, I have recently rescued a 1956 Grumman Olson stepvan on a Chevy forward control chassis. Tag on the steering column says 3d58t. Got her running and moving under her own power. My goal is to put it back on the road, improve the brakes and steering/handling for a bit of a safer ride. There doesn’t seam to be a ton of info on modifying these vans out there but if the info is anywhere it’s here.
Very cool van. Welcome
Welcome to the Stovebolt madness. There is no cure! shake
Welcome to the 'bolt.
Please scroll through the various forums to see what they have to offer.
Make sure to check out the rules of the page as well.
Questions pertaining to your problem are welcome and will usually get answered quickly.
There are many "how I done it's" here as well that can be found using the search feature.
Another quality post.
Real Trucks Rattle
A nice fine and a nice project. I know there is a couple guys here that have them. I think one of the guys is named Victor but don't know his Stovebolt handle.
Good luck and we are here to help you on your journey.
Closed body trucks are nice and useful especially if you can stand up in them. They keep your stuff dry and they can make a great advertising platform for your business. The grille bars on yours are reminiscent of an Advance Design truck. What engine does it have?
You can learn a lot here, I sure have.
Camp Commandant
Camp Commandant
Welcome Tikitech, fellow Old Dominion Stovebolter Victor has a beautiful '55 Grumman Olsen. I was trying to find a picture but will have to wait until I am on my personal computer. Ever since I saw his in person, I have had a thing for them.
Great rescue and good luck with your project.
~ Billy
1959 GMC 860 | Pictures
Great looking Van! Welcome to the forum and have fun with getting it out on the road again.
Welcome, I'm located in Hopewell, there are a few others near the shore and just over the PA border, in Bucks county area. Nice project!
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
thank you for the warm welcome gentleman! frogfarmer, it originally came with the 265 but was replaced with a 350 in 1968. I found a hand written note on the wall inside saying it was replaced at 87000 miles in 68 and signed by the mechanic. I thought that was cool. Still has the original sm420 trans. Bill, I will defiantly look up victor thanks! diseasel, good to know there are some local Stovebolters around! I will be posting questions and updates in the Tons 'o Fun section, there is no van forum so I am guessing that's where I should post.
Tikitech, you can still post questions in the other forums. For the driveline just post the questions in the Driveline Forum, engine questions in the Engine Forum and so on.......It may be a van but many/most questions pertain to many models.
will do Achipmunk,thanks for the tip.
V
VEW Offline
V Offline
Hi Tikiteck,
Welcome to Stovebolt! It's a great site for many reasons: great folks and just a wealth of free flowing knowledge!
We have a 55 Grumman. It's still pretty much original, but I did install an overdrive (56, R10) unit on it. I use it for camping. I'll be glad to share what I know (that shouldn't take long smile ).
Mill Supply is a good source for Grumman parts. I'm usually around everyday, but if you don't get an answer to what you're looking for, feel free to PM me.
They are great utilitarian trucks!
Good luck with your project!
~ Victor
1957 3100 - moved on
Hey vew,
that is a nice looking van! I have made some good progress on mine, paint removal and wiring mostly. I do have a question. I am looking to convert from duel rear tires to singles.figuring out what rims fit has been a bit of a challenge. what size/type of rims are on yours? Do you know of any one selling new rims that fit or any more modern junk yard finds that may work? Thanks for sharing your pics!
24601
Some more shots of Victor's van. VEW once made a very unwise decision to let Billy and I take it for a spin ... Man that van is fun to drive! I was a little concerned when Billy had it up on two wheels, but it turned out ok... smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
great pics! motivates me to get mine done for sure. 2 wheels?!?! haha! that needs to be a YouTube video! thanks for sharing those.
V
VEW Offline
V Offline
John, you and Billy are BAD BOYS!!! And I'm not going to let you drive Doughboy ever again - - - unless you want to smile
Tiki, I have a 3/4 ton, 8 lug, FF rear differential in mine. 16" wheels. I've never checked for aftermarket wheels.
If you just want single rear wheels, why don't you just remove the inner wheels? You may need to press in shorter lug bolts....maybe.
I could be missing something...wouldn't be the first time!
~ Victor
I had The same Idea VEW but the offset on the 19.5 dually wheels makes them look either way too far out or way too far in (tried both ways things got real weird back there). Also if any of you guys are ever near NJ feel free to 2 wheel my van anytime!
V
VEW Offline
V Offline
OK, so you have those wheels. I have them on the 41 I'm building and it will be duals.
I've read on this site that aftermarket wheels are available in that size. I was reading someone wanted to use trailer wheels of that size because there was a better selection available. Do a search, probably in the Driveline Section and see what you can find. Plenty of info on this site.
Good Luck!
~ Victor
