4 members (papas52, Otto Skorzeny, 1955 1 Series, 39Master85), 75 guests, and 3 robots.
Topics128,083
Posts1,056,326
Members48,442
#129684 03/27/2004 7:51 PM
Hello all,
Bryan Bauman
Hello Bryan: Can't help with the assembly but just wanted to say Hi!!! Somebody will help ya after the kids get done playing name change, and tag. popcorn The Truth is Out There (You will find us a loveable bunch just odder than most)
what specificly are you wanting to know.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
Ron, do you have some kind of brake pedal return spring on the pedal linkage of your '42? I'm getting ideas for mine, 'cause it's kinda weak on the pedal return.
I went out to the shop and checked it over and i have no return spring.I looked in the manual and it shows no spring other than the one in the mastercylender.I rebuilt the cylender when i got the truck and cant remember but i asume a rebuild kit comes with a new spring.I do remember that napa had the kit on the shelf.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
Thanks for the info. I have a reprint of a 1946 Chevy truck owners manuel (do you have that one?) and it shows in a picture on page 11 that there is a return spring for the linkage connected to the frame. Does your pedal pop up good and strong? 'Cause I rebuilt mine and it's kinda weak. john.
John,ive got an original 1942 shop manual.I checked again in section 5,hydraulic brake repair, and can find no mention of a return spring.I even looked at mine again and there is no external spring or any place i can see where one should be.The cluch pedal has a hook on it for a spring but not the brake pedal.Mine returns freely and strong all the way up. Ron.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
My 46 (47 first series) has a return spring.
Tim
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Tim does your spring setup look like this pic below? I don't have that. I was thinking about inprovising and adding a spring from the clevis pin to the frame (or the splash pan). This pic was taken from the little 55 page owners manuel for 1946 trucks (not the shop manuel).
[img]http://img.villagephotos.com/p/2003-9/378428/brake_pic.JPG[/img]
Mine has a spring from the clevis pin and hooks to the splash pan close to where the spring for the clutch pedal is. There isn't an eye on my pedal as shown in the picture that John posted. The clevis pin is a little bit long, just enough to hook the spring to. The spring has a piece of heavy wire hooked to it as an extension.
I think you should have some kind of return spring just to make sure that you aren't dragging your brakes. In some cases just the weight of the pedal can cause the brakes to drag just a bit. Better safe than sorry.
George
