7 members (Goach2, Gdads51, Bill Hanlon, TexasA&M48Truck, 2-Ton, Southerntruck, NJC), 124 guests, and 3 robots.
Topics128,204
Posts1,057,302
Members48,467
How was the vacuum advance "plumbing" routed on a 1946/47 217 engine routed - where was the fitting for the intake/carburetor vacuum source?
Photos would be appreciated.
Hope this answers your question. There is a clamp holding the line to the top/side of the thermostat housing.
The vacuum line connects into the backside of the carb base.
Harold
Harold
Thanks Harold.
Is the vacuum fitting on the carburetor pressed into the carburetor, or screwed into a threaded hole in the carburetor/base?
Harold
Harold,
The idle mixture screw is located right about this line, correct?
Screw A in this image:
http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm637.htm
Do you have an image of screw B- idle speed adjustment screw?
Andy
"Is the vacuum fitting on the carburetor pressed into the carburetor, or screwed into a threaded hole in the carburetor/base?"
It is a threaded connection on the W-1 carb. You can see this connection in this photo.
Harold
Harold
[quote]Harold,
/quote]
Andy, This is the best photo I have showing screw "B".
Harold
Harold
[quote]Harold,
/quote]
Harold
Harold is it the one directly on the linkage mechanism?
[quote]Harold,
/quote]
Harold
Is this correct?:
https://photos.app.goo.gl/9mkSCEe34HdGA13n7
Andy,
Yes, the mark up in the photo of "B' is correct.
Harold
Harold
