9 members (GMCJammer51, Hawkman, Guitplayer, Uncles51, Dennys28, walterhvogel, Ponchogl, WICruiser, 1955 1 Series),
55
Mod | | | Forums66 Topics128,017 Posts1,055,256 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Ok, I've been reading posts, and checking other sites. What I really need, is recommendations for a single carb setup for my 235 ci stock engine, best performance and fuel economy. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Everyone has their own opinion whether right or wrong. Ultimately it is your dollar not ours. What someone here recommends might not necessarily be the best for your application. You say you have done a Stovebolt site search? If so, you are going to get the same information from this post as you read in your search. Good luck.
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | best performance and fuel economy are not quite opposites, but represent different values of "best". | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Like others have mentioned, the term "best" has different meanings to different folks. In the area or carburetor replacement; many would consider:
(A) power (B) fuel economy (C) reliability (D) appearance (E) initial cost
Your call.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2014 Posts: 4,473 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,473 | It also depends on how frequently you start and use the truck. As has been discussed here before, engines which don't get used often will probably do better with some carburetors than others...
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | There are 2 different carburetor flange patterns as to bolt spacing used on the 235. 216, early 235: 2-11/16" SAE #2 Late 235, 261 2-15/16" SAE #3 This narrows the carburetor choice to what fits your engine. | | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | FWIW, I wanted to stay period correct, so replaced the Rochester B (SAE 3 flange) that was on on my '53 (w/ '54 passenger 235) with an NOS Chevy-spec Stromberg BXVD-35 I picked up (#380295, stamped 14-25, electric auto choke), and it made a world of difference in drivability and smoothness. Of course, the Rochester B was warped and leaking... so maybe not quite a fair comparison. Best option? IDK, but I'm very happy with the Stromberg. For reference, the equivalent BXVD-3 manual choke carb is #380286, code 14-24. Just one option...
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | DrDoug - FWIW, I would rate the Stromberg at the top (or tied for the top) in categories above post of (A), (B), and (C). (D) is subjective (do you like blue eyes or brown?). I don't generally recommend the Stromberg as it will generally be at the top of the price scale (E) above (highest).
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | Thanks, Jon. I've managed to pick up a few reasonably priced NOS Stromberg carbs over the past several years. It does take patience... lot's of the ones that pop up are crazy $$$$. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Don't really care about beauty/appearance, looking more into a well rounded performance two barrel, with enough cfm not to choke or overwhelm the motor, which came out of a '56. | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | Oh come on...instead of all the vagueness, qualifiers and hedging, somebody have the fortitude to give the guy an actual recommendation! He asked what YOU like, so tell him what works for you and why! | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Thank you Jay!! What I've been seeing is the two barrel is the most prominently used. weber 32/36 or 38, ford 300. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I've also seen 4 barrels used, but don't want to over carb the motor. If it's possible to use a 4bbl what size would be appropriate? | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | How to avoid over carbureting the motor: don't put your foot down all the way. | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | I've also seen 4 barrels used, but don't want to over carb the motor. If it's possible to use a 4bbl what size would be appropriate? 200 CFM Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
