Hope this answers your question. There is a clamp holding the line to the top/side of the thermostat housing. The vacuum line connects into the backside of the carb base. Harold
"Is the vacuum fitting on the carburetor pressed into the carburetor, or screwed into a threaded hole in the carburetor/base?" It is a threaded connection on the W-1 carb. You can see this connection in this photo. Harold .
[quote]Harold, The idle mixture screw is located right about this line, correct? Screw A in this image: http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm637.htm Do you have an image of screw B- idle speed adjustment screw?/quote] Andy, This is the best photo I have showing screw "B". Harold
Harold is it the one directly on the linkage mechanism?
