| | | Forums66 Topics128,195 Posts1,057,377 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2018 Posts: 6 New Guy | | New Guy Joined: Dec 2018 Posts: 6 | I have a 1955 1st series and need help regarding how my truck bed is resting on the frame. Its tilted to the right. I have owned this truck for a long time, and the bed has always leaned to the right. The drive is fine, drives straight no pulling. I am in the process of doing some restoration and would like to understand if this was intentional or I require more "blocks" under the right to level the bed. I have seen other photos that seem to show a slight tilt on other 55s so I had to ask and looking for comment. Project 33 1955 1st Series | | | | | Joined: Jul 2000 Posts: 2,207 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,207 | We can only guess. Assuming the truck has the stock bed (no blocks, as Tim said), I suspect the springs. You need to park on a level surface and measure from the axle to the frame on both sides and see if the measurement is equal.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2018 Posts: 6 New Guy | | New Guy Joined: Dec 2018 Posts: 6 | Thank you. its a 1955 1st series. Bed sides are straight to the rolled edge.. aka flat. I will measure today and get back to you.. Project 33 1955 1st Series | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | P33, does your truck have the driver's side spare tire mount and is it a 1/2 ton model? If memory serves me right, there was a spacer on the right side only between the leaf spring pack and the axle tube mount. This lowered the right side to match the weight of the spare tire and bracket assembly on the left side. If your side spare is gone and/or mount removed and the spacer is still there, it could be the reason.
As others have said, worn springs and/or shackle pins, shackle bolts can tweak the rear look too.
Steve
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
