5 members (HandyAndy, 2-Ton, 78buckshot, TUTS 59, Wally / Montana), 91 guests, and 2 robots.
Topics128,060
Posts1,055,835
Ready to drop in the new 350 in my 39. When I mocked up the motor I didnt put a fuel pump on the motor. Now it looks like it wont fit due to the narrowing of the frame and where I located my Heidts crossmember. Any recomendations on electric pumps. Im also ready to run the fuel line so I guess I need to plan for an electric pump.
All I can say is get a good one. I got a cheapo (about $100) and the ticking drives me nuts, sounds like a real bad lifter. With the noise coming from the back of the truck.
Socket Breaker
Socket Breaker
a hot roddin' pal of mine used a purolator electric fuel pump on his rodded '68 fairlane - he was running a small block 302.
He keeps telling me I should get one for my '65 chevy, which I have a 350 in it with whatever electric pump came on it.
Holley and Edelbrock both make electric pumps... cost more, put out more pressure.
-W
if you are running a carburetor,watch that the electric pump doesn't give more fuel pressure than the carb needs. you might need to use a pressure regulator along with your new pump. good luck.
our garage is a non-profit organization
I plan on using a Holley Blue with a pressure regulator. We used to use these in racing applications and had excellent luck with them.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
thanks guys
