0 members (),
166
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Ready to drop in the new 350 in my 39. When I mocked up the motor I didnt put a fuel pump on the motor. Now it looks like it wont fit due to the narrowing of the frame and where I located my Heidts crossmember. Any recomendations on electric pumps. Im also ready to run the fuel line so I guess I need to plan for an electric pump. | | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | All I can say is get a good one. I got a cheapo (about $100) and the ticking drives me nuts, sounds like a real bad lifter. With the noise coming from the back of the truck. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | a hot roddin' pal of mine used a purolator electric fuel pump on his rodded '68 fairlane - he was running a small block 302.
He keeps telling me I should get one for my '65 chevy, which I have a 350 in it with whatever electric pump came on it.
Holley and Edelbrock both make electric pumps... cost more, put out more pressure.
-W | | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | if you are running a carburetor,watch that the electric pump doesn't give more fuel pressure than the carb needs. you might need to use a pressure regulator along with your new pump. good luck.
our garage is a non-profit organization
| | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I plan on using a Holley Blue with a pressure regulator. We used to use these in racing applications and had excellent luck with them.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | | | |
