1 members (78buckshot), 64 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
#1295205 01/17/2019 8:32 PM
Hi guys,
Now that I’ve swapped gears my 48 really gets down the road but stopping is another story. So I’ve decided to do a brake job. Since this is my first time working with drum brakes I’m doing a lot of reading and taking my time. I ordered new shoes and cylinders but when I took the drums in to get cut there’s nothing to cut. So I’m looking for new drums and they don’t seem as readily available as I thought they would. So my question is where is a good place to get them or can I use another year (found 51 that seem like the same)?
It’s a 1/2 ton.
' Offline
A 1951 drum WILL NOT work on your 1948 1/2 ton.
Front or Rear drums ?
Do you prefer junk yard / parts truck used drums - Chinese Repro's - or - Genuine GM NOS drums ?
Chevs of the 40's sells repro drums
https://www.chevsofthe40s.com/detail/13269/Chevrolet_Brake_Drum_Front_For_12ton_Commercial_6Lug.html
https://www.chevsofthe40s.com/detail/6339/Chevrolet_Brake_Drum_Rear_12t_3742_34t.html
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Thanks George I just ordered them from there!
' Offline
Jim , Hope you got your 15% DISCOUNT
as they were on sale until Jan.20, 2019 .
That's a substantial saving .
If these repro drums are made in china I'd have them measured
to make sure they are measurement True .
I've heard that even new repro drums need to be turned to get them True .
Are your 70 year old brake metal lines original ?
You can get all kinds of restoration brake parts from Inline Tube .
http://online.flipbuilder.com/wmmk/bhbt/mobile/index.html
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Hi George,
I put the code in but did not get the discount. I’m going to call them Monday. Thanks for the tip on the drums, I’ll check them before I use them. Somewhere down the line some of the previous owners already changed most of the brake lines so I only had to do a few of them. Got lucky there, but I did swap out to a dual master cylinder, thought it would be safer. Thanks for the help it is much appreciated!
