5 members (55shaker, Rich'sToys, 59 fleet, pdlightning, 1 invisible), 140 guests, and 5 robots.
Topics128,077
Posts1,056,032
Members48,433
#1295317 01/18/2019 6:47 PM
Hi guys while I wait for my rear drums so I can finish my brakes I decided to change the rear shackles. I was able to get the old ones out by heating them up and pounding them out. So my question is how do I get the new ones in? Is there a press type tool for this task or some other way? I didn’t realize the new ones would be so tight! Thanks
Some of us use a puller made from bits and pieces from the hardware store. There may be examples in past posts.
1951 1 Ton Completed
Former BMW Rider
Former BMW Rider
Check out this material from Pre '68 Dave. I used his method and it worked like a charm!
Chev 235 guy
Good luck!
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
I had contrarian parts. That bolt bent for me.
Here is the set-up that I used.
Thanks for the advice, I was able to get one new one in before the bolt in my setup (which is a combination of the ideas you guys gave) broke. I think I got it figured out, I need a stronger bolt! Thanks for the help! I’ll post a pic of my setup when I get back to it.
Hi guys I got my shackles on and in place but was wondering if anyone knows what the bolt should be torqued too? The new shackles have a rubber washer and those seem to crush pretty easy and I don’t want to over tighten. Thanks
If I remember correctly, where there are threaded shackle pins, the nuts are self locking. So the idea would be to snug the nuts up until the rubber washers are acting as seals.
Former BMW Rider
Former BMW Rider
The shop manual says to 'tighten securely'.
1/2 TON REAR SPRING
Andy
That probably doesn't fall into the category of "torque till it breaks and back off a half turn" wink
If one uses the original shackle arms, you tighten them just before they start to get looser.
If the shackle arms are after market, you tighten them just before the arms bend. They are not make of the correct steel.
Thanks guys
