1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | Porky Here..
another dumb question..
i have a 59 apache with the standard heater. the inlet is 3/4" and the outlet is 5/8". i bought just 3/4" hose and have 3/4" fittings at the thermostat and water pump.
will i be ok if i use the 3/4" hose over the 5/8" male outlet on the heater with a 3/4" old style clamp or do i really need 5/8" hose too?
porkchop
1959 Chevy Fleetside 3100 Series BBW
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It's OK with me.  It will have a place to leak though. Try it. Not what I would do now but I have done worse in my yute.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I wouldn't. I have done worse too but its not worth the chance of splitting the hose or blowing off. It looks bad to someone familiar with these trucks. You can get a fitting to replace the one in the therm. housing. I can't imagine why it would have a 3/4 " fitting to began with. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Two tandem modern clamps may be needed to squeeze a 3/4 around a 5/8. 3 ft of 5/8 and another fitting is not that much to do it right.
