2 members (Hotrod Lincoln, TexasA&M48Truck), 186 guests, and 1 robot.
Topics128,082
Posts1,055,964
Members48,430
Porky Here..
another dumb question..
i have a 59 apache with the standard heater. the inlet is 3/4" and the outlet is 5/8". i bought just 3/4" hose and have 3/4" fittings at the thermostat and water pump.
will i be ok if i use the 3/4" hose over the 5/8" male outlet on the heater with a 3/4" old style clamp or do i really need 5/8" hose too?
porkchop
1959 Chevy Fleetside 3100 Series BBW
Sir Searchalot
Sir Searchalot
It's OK with me. smile It will have a place to leak though. Try it.
Not what I would do now but I have done worse in my yute.
Riding in the Passing Lane
I wouldn't. I have done worse too but its not worth the chance of splitting the hose or blowing off. It looks bad to someone familiar with these trucks. You can get a fitting to replace the one in the therm. housing. I can't imagine why it would have a 3/4 " fitting to began with.
George
1972 Chevy c10 Cheyenne Super
Sir Searchalot
Sir Searchalot
Two tandem modern clamps may be needed to squeeze a 3/4 around a 5/8. 3 ft of 5/8 and another fitting is not that much to do it right.
