8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL), 100 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
#1294268 01/10/2019 5:25 PM
so i have what i'm pretty sure is a sm 420. there are a bunch of numbers cast into it. on the cover, GM6, 591588, on the side is j 1860 which i think is date code for oct 18 1960?
then under that, the number 3 and under that, 3761930. there is also the letter T stamped in the side. in addition, there is a spicer box coming out of what i think is a PTO on the side.
any help would be great.
thanks
doobspanel #1294270 01/10/2019 5:45 PM
doobspanel #1294282 01/10/2019 7:10 PM
yes, that did. so why is there the spicer box bolted to the drivers side of the tranny? i'm guessing that is a pto? would it have been used to run something off the truck? can i just remove it and find a cover for it?
thanks
doobspanel #1294286 01/10/2019 7:25 PM
You can remove that PTO and get a cover for the opening. The bolt pattern has been the same for ages. I think I've seen new covers for $10, but you could browse the junkyard and probably find one off a dead tranny for next to nothing.
doobspanel #1294509 01/12/2019 5:51 AM
Or just make one from a piece of flat stock metal.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
doobspanel #1294645 01/13/2019 1:28 AM
Crusing in the Passing Lane
When you remove the PTO, label it as coming off a 420, otherwise it will be useless to someone who wants one. PTO's are very hard to identify if off the trans. Could even put # of teeth and pitch(straight or helix) of the drive gear on it.
Ed
doobspanel #1294767 01/13/2019 10:08 PM
good advice, thanks
doobspanel #1295182 01/17/2019 4:51 PM
You can purchase a PTO cover from Novak (see tclederman's earlier post) . Its Novak part number K-PTO , list for $41.00 . Enjoy!
Ron - - Dusty53
1954 Chevy 3604
EdPruss #1295184 01/17/2019 5:37 PM
Ed
Are the PTO's sought after?
1953 Canadian GMC 9314 w/ (factory) Chevy 235
doobspanel #1295188 01/17/2019 6:21 PM
People with big trucks, in particular, might one one. If you have one, and you know what type/year transmission it came out of, post a Parts For Sale listing in the Swap Meet.
tclederman #1295300 01/18/2019 4:12 PM
I don't at the moment, I'm just waiting to hear back from the seller of an SM420 that has a PTO on it. I wouldn't want the PTO which is why I asked.
doobspanel #1295303 01/18/2019 4:48 PM
Put a tag on the PTO - containing information (if available) about the transmission
- type of transmission
- vehicle type and year it came on/with
- year of the transmission (if you can ID that)
- any casting code/date on the transmission
