4 members (WICruiser, Bill Hanlon, Hanks custodian, 66flea), 235 guests, and 3 robots.
Topics128,078
Posts1,056,049
Members48,433
#129521 08/05/2003 5:52 PM
Ok..i'm down to just the cab and frame on the truck and i'm doing some planning. I have a lead on a posi rear end out of a transam/camaro. I'm going with the mustang II in the front. Anyone know what kind of tire I can stuff on the front in an 18" and what about a 20x10" in the rear?
#129522 08/06/2003 9:30 AM
I don't get it. Are you intentionally mismatching the tires? How many spares do you plan to carry around?
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#129523 08/06/2003 7:07 PM
all you need is a spare tire that is the same height as the rear tires. That way, if you get a flat, you can put the spare on and not have to worry about the posi burning up on you. If you have a front flat tire, your pickup might just look kinda tilted, but that wont hurt anything.
18's and 20's are good combos, but havent seen great rims that big on a nice look AD yet. Oh yea, you might need to tub the box a little bit for the 10" wide rims out back.
Drew
55 2 dr 210- after college project
56 2 dr 210- after '55 project
"D'oh"
#129524 08/07/2003 5:44 AM
Quote
you can get 18" tires that are the same overall diameter as the 20" tires. Which both will be a smaller diameter than a 235/75/15
#129525 08/08/2003 1:45 PM
