7 members (TUTS 59, Peggy M, Gdads51, 68ironhead, tclederman, 2-Ton, wilbur53),
154
7
Mod | | | Forums66 Topics128,281 Posts1,058,476 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 24 Member | | Member Joined: Apr 2003 Posts: 24 | Ok..i'm down to just the cab and frame on the truck and i'm doing some planning. I have a lead on a posi rear end out of a transam/camaro. I'm going with the mustang II in the front. Anyone know what kind of tire I can stuff on the front in an 18" and what about a 20x10" in the rear? | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I don't get it. Are you intentionally mismatching the tires? How many spares do you plan to carry around? | | | | | Joined: Apr 2002 Posts: 23 Member | | Member Joined: Apr 2002 Posts: 23 | all you need is a spare tire that is the same height as the rear tires. That way, if you get a flat, you can put the spare on and not have to worry about the posi burning up on you. If you have a front flat tire, your pickup might just look kinda tilted, but that wont hurt anything.
18's and 20's are good combos, but havent seen great rims that big on a nice look AD yet. Oh yea, you might need to tub the box a little bit for the 10" wide rims out back.
Drew
55 2 dr 210- after college project 56 2 dr 210- after '55 project "D'oh"
| | | | | Joined: Apr 2003 Posts: 24 Member | | Member Joined: Apr 2003 Posts: 24 | Originally posted by Hedgehog: I don't get it. Are you intentionally mismatching the tires? How many spares do you plan to carry around? you can get 18" tires that are the same overall diameter as the 20" tires. Which both will be a smaller diameter than a 235/75/15 | | | | | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | | | |
