7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible),
125
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | My 53 Chevy 1/2 ton has a torque tube with the universal joints incased in a ball type housing. ..How much oil do I put in the hole which is in the tail shaft of the tranny ? This hole takes the small plug with the peg on it...…...thanks
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
| | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | The service manual says 1/2 pint. Service Manual page 4-16
Greg Brown
| | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | Sorry just realized the search engine took me to the car manual, not the truck manual. Here's a link to the truck manual which just says "fill housing with transmission fluid" for the 1/2 ton trucks, but says 1 pint for 3/4 ton trucks. Truck Service Manual page 4-52
Greg Brown
| | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Greg...in that article on page 4-52 it states to remove the Speedo drive gear and fill with tranny lubricant. DOES THIS MEAN TO FILL THRU THE SPEEDO DRIVE OPENING HOLE ???
If I read the instructions correctly on page 4-53,it would need one pint. ....
In transmission section 7-4,paragraph 6, it states to fill the universal joint thru the pipe plug opening ...but which plug opening, the one on the tail shaft which is called the (bearing support retainer plug) or does it mean the main tranny fill plug in the mid - section of the tranny case ??? It does state that the main tranny takes 1 1/2 pints
I need to get this right...…….
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://chevy.oldcarmanualproject.com/chevyowner/53tom76.htmThere is a filler plug/hole on the upper passenger side of the SM420 transmission. The instructions above say to fill to the plug hole. Other instructions might say: when cold/cool, fill a little below the plug hole (the oil expands when warm). As posted above, the enclosed drive-shaft transmission u-joint is filled from the transmission. | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | THANKS FOR CLEARING THAT UP FOR ME...J
