6 members (Shade Baby, TexasA&M48Truck, tclederman, Hotrod Lincoln, Bill Hanlon, 1 invisible), 82 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
does anyone have any suggestion for the lubricant to use on the window regulator or the window track on the window. Both had old grease which was hard and very sticky. have cleanded them up but was wondering what might be best to go back with. thanks for any suggestion you might have.
Frank
I use white grease that was made for my garage door.
I'll probably be moving this post to another forum. FYI.
Another quality post.
Real Trucks Rattle
I've had good results with never seize. It can be messy, but you shouldn't need to replace the glass (and get into the mess) as often as the fleet trucks and off road equipment I used to work on. John
In what condition are your leather washers which ride in the channels? They look like rollers, but they do not roll. If your leathers are beat up, a slick trick is to use the aftermarket rollers.
